Viper RC -
#2656
Hey guys, I have a VTX10 8.5t combo that I am having trouble with. I got the radio calibrated and all the lights are doing the right thing, but I am getting nothing from the motor. I tried to spin the spur and I get a stutter from the motor but that is it. ESC got really hot fast trying to figure it out so I figure I would ask y'all. Any Ideas?
#2660
whats the max safe temp on the 4.5xl motor? i am running mine in a scte with a 14tooth pinion, endbell timming at 30 degrees, no esc timing, ind0or clay track and after a 7 min main it comes off at between 168-175.
Great motor by the way. way more torque than the epic 550 i used to run.
#2662
Hey Bobby, I don't run buggy so I am clueless when it comes to buggy setups. I did however send an email out to a few guys on Team Viper for some help. If you want to PM me your email I will send you the settings once I receive them.
The wires are per-installed with high capacity bullet connectors. And bullet plugs on the ESC plug and play. The wires do come out of the motor (like in the 3D render). You can trim the wires as needed.
#2667
led on v port aren't on.hook up to progauge to try set speedcontoll and all that comes up is connect failure. it does shut off and on but seems to be stuck on profile 2.when turned on it will beep.any clues what to do.thanks lance
#2668
Negative, 2-3S only on the VTX's.
Lance, when you power on the ESC wait for the tones to arm, hold the button down for one second you will see the lights on the VPort switch to red/orange LED's. Now pluggin your ProGauge and "Link Device".
If you still can't get it, PM me your phone number I will give you a call and see if I can help.
#2670
4Likes
