Viper R/C Solutions - A New Line of Innovative Power systems!
#1186
Josh didn't use one at IIC with his 4.5 (I think he ran 3.5 in a qualifier, at least he was talking about it).
Eric did run a fan on his car with 17.5, but just the motor, not the speedo. We might need to look into set up silvalis to see if we can help keep the temps down, or at least controllable.
My apologies, I owe someone Josh's TC speedo set up, I thought they posted it on the site, but they did not. I have to get it from him and I will post it when I have it.
#1187
Chris i would suggest a d3.5 for 10.5 OVER THE REEDY motor . and as for speedo's getting hot can you give some more info like track size motor air temp gearing are you running alot of boost and turbo ? josh's speedo in both sedan and 1/12 were warm but no where near thermaling and my stuff was not even warm
also settings in speedo what was cutoff for speedo temp set at ?
mark
mark
#1188
If you run the right esc parameters and the right gearing, both the esc and the motor shouldn't need a fan. What i always do is leave a conservative blinky setup on the speedo and gear the motor until both motor and speedo are the same temp, lets say 115* then i play with gearing to get maximum speed. Usually the difference from motor to esc should be 20-30 degrees hotter on the motor. It takes some time to tune modified motors so you have to test and keep track of temps.
Also take traction into consideration. More or less traction can both heat up the motor.
#1189
Josh Cyrul's Touring Car Setup with boost
#1190
mark
mark
#1191
Had a practice night yesterday and the throttle "glitched" on me two times with the new settings... I ran in "Practice" mode (i.e. with reverse enabled) and I'm starting to suspect the glitching has something to do with that mode (or the reverse I should say). Changed to "Race open" mode and I did not get any more glitch that evening. The problem is really intermittent but the only pattern I see is that the glitch is coming directly after I have giving brake but I'm not 100% sure of it.
As I said before I'm running the A30 firmare (came with the ESC). I don't want to spend another $25 + shipping on a computer cable just to try the A55 firmware as someone suggested. If this was a confirmed bug than yes, I would definitely upgrade, but now I'm not even sure if the ESC is a keeper. Can't afford to have an unreliable ESC when racing...
#1192
Macke, PM me all the settings from the esc, what kind of radio and servo you are using. So I can take a look at it and even try and replicate it. Something has be to causing it, it's not a widespread issue with out product set, so we have to look at all the info to see why it's happening. We don't want you to think its "unreliable", it's not a problem we are seeing elsewhere.
#1193
#1194
Hey guys, the ARC R10 1/10 touring car kits are in stock ready to ship. We also have all our Viper products in stock as well. Have a great week!!!
www.shopviperrc.com
www.shopviperrc.com
#1195
Looking at switching from a Tekin rs pro to viper. I run mostly 1/10 2wd offroad buggy 17.5 blinky but like to run a 7.5 every so often. Am I going to be leaning toward the VTX1 or the VTX10R. Smyka told me the 1 is single circuit board and the 10R is dual but what are the differences.
#1196
#1197
Had a good race last sunday in my WGT car. Qualified 4th in the A and finished 3rd. Getting used to the new motor so will get quicker. Here are the settings I used qill update the more I use it.
Reedy Sonic 10.5 motor small amount of timing on the can.
1 Cell
52mmpr
BRAKE
Strength 80%
PWM Freq 3200hz
Linear
Throttle
pwm freq 5000hz
punch 100%
curve linear
band narrrow
MOTOR POWER
start rpm 3000
finish rpm 11000
Max timing 35
TOP SPEED TIMING
Slew 5
Max timing 18
small update to my blog
http://rcgtpancars.blogspot.co.uk/
1 Cell
52mmpr
BRAKE
Strength 80%
PWM Freq 3200hz
Linear
Throttle
pwm freq 5000hz
punch 100%
curve linear
band narrrow
MOTOR POWER
start rpm 3000
finish rpm 11000
Max timing 35
TOP SPEED TIMING
Slew 5
Max timing 18
#1198
Looks hella fun
#1199
viper combo
Hi Viper,
I really thought the viper esc/motor/pro gauge combo is a good deal.
But...
VTX10R sensored brushless racing system with VST2.5
VTX10R sensored brushless racing system with VST3.5
2.5T and 3.5T on 2S VTX10R ?
Wouldn't it be great to have a combo for VTX1 for 1S ? especially for 3.5T & 4.5T on 1/12.
Seriously, I dunno how you can run a 2.5T on 2S. :P
But...
