Savox Servos
Old 01-07-2011 | 04:47 PM
  #121
stu541's Avatar
guss.
I just did that exact change over. I have yet to put power to them but I will try to soon and report back.
stu541 is offline
Old 01-07-2011 | 05:11 PM
  #122
stu541's Avatar
ok so I just went and set my trims. WOW. If these things perform like I think they will, dang. I was worred about the 1268 being slow for steering but put it there anyways. It is smokin fast. the 1268 can be used for th/b and steering no problem.
stu541 is offline
Old 01-10-2011 | 05:04 AM
  #123
Stalkie's Avatar
Has anyone used the 1258 for steering in a 1/8 nitro buggy....I have just put an order in for two of them for my new kit??
Stalkie is offline
Old 01-10-2011 | 06:04 AM
  #124
td-civ's Avatar
i would of got the 1265tg for your steering and a 1257tg for t/b but the 1258will do the job
td-civ is offline
Old 01-10-2011 | 07:57 PM
  #125
etivac13's Avatar
anyone using savox with m11x? are you using NOR or HRS? thanks.
etivac13 is offline
Old 01-10-2011 | 08:06 PM
  #126
td-civ's Avatar
it dont matter
td-civ is offline
Old 01-10-2011 | 10:13 PM
  #127
Dlewis4's Avatar
R/C Tech Elite Member
Contact me for thebest possible deal on Savox servo's thru Premierehobbies.com
Dlewis4 is offline
Old 01-10-2011 | 10:26 PM
  #128
nexxus's Avatar
Super Moderator
Guys just be aware the Castle Mamba Max Pro ESC will not run a Savox 1267MG Servo on it's own. I've had to use an external BEC to power it (amp hungry)
nexxus is offline
Old 01-11-2011 | 01:42 AM
  #129
etivac13's Avatar
what BEC did you use? i'm getting a 1257 for throttle and a 1256 for steering.. i might get a BEC as well...
etivac13 is offline
Old 01-11-2011 | 02:37 PM
  #130
Default savox servo
I just tried to install a 1256 into my new hyper 10 sc with the new Castle SC mamba max pro with 2400 kv motor, but found that the castle doesn't put out enough volts to run this servo. I need to put a bec into the car in order to run savox servos. Switching back to JR 9100T. No problem with the JR servos when using MMP
burgerchow is offline
Old 01-11-2011 | 06:21 PM
  #131
rangerjkb's Avatar
Savox are some great servos, just switched over from Futaba BLS. "pm" Dlewis4 for some great deals on Savox servos through Premiere Hobbies!!!!
rangerjkb is offline
Old 01-13-2011 | 02:03 PM
  #132
1bigshane's Avatar
i am a highdoller hitec man, but i just bought a bunch of these ! i will put them to the test! ill keep u guys updated they were 1257,1267,1268
1bigshane is offline
Old 01-15-2011 | 05:17 PM
  #133
rangerjkb's Avatar
If your using the HV rated servos, you may need an external Rx capacitor to provide uninterupted power (somthing similar to the Spektrum SPM1600). The non-HV servo line doesn't require the capacitor for top level performance. Awesome servos, they are smoking fast and extremely strong!
Old 01-15-2011 | 07:24 PM
  #134
To my dismay I found that I need a cap even at 6v using a Spektrum SR3001 rx and a 1257 Savox servo.
AreCee is offline
Old 01-23-2011 | 01:17 AM
  #135
Funking-Awesome's Avatar
Will the 1258 and 1256 run on straight LiPo? I do not run regulators, it's just another link in the chain to go wrong.
Funking-Awesome is offline
