Savox Servos
Old 12-31-2011 | 03:43 PM
  #541
So*Cal AFDude's Avatar
Originally Posted by cla5675
Hey, guys. I just picked up a 1258TG servo for my FT SC10. I was testing the servo before installing it and I would get a "brown" out when the servo tunred to one side. Meaning the servo would stop turning and there would be a momentary power loss to the servo and receiver. I tried another receiver and the same thing would happen. Anyone else ran into this problem? I'm thinking I got a bad servo but want to be sure before I send it back to AMain Hobbies. Thanks!
Troy.
Get a Spektrum glitch buster.
So*Cal AFDude is offline
Old 12-31-2011 | 06:07 PM
  #542
ozzy-crawl's Avatar
When you set your end points it should eliminate some of that
But as posted by so*cal afdude a glitch buster from spectrum will fix it or if your a cheap skate like me buy a 4700uf 10 volt cap and use a old servo extension and make your own for a buck or 2
ozzy-crawl is offline
Old 01-01-2012 | 06:23 AM
  #543
cla5675's Avatar
Thanks for the info guys!!
Troy.
cla5675 is offline
Old 01-01-2012 | 06:47 PM
  #544
We make our own as well. Just used Spekys as a reference because they're larger than Novaks
Old 01-01-2012 | 07:18 PM
  #545
drs92's Avatar
Guys, I'm gonna be straight to the point, I'm lost and looking for help lol
Getting major glitching/brown out issues. It's severe and I loose all control and can see the rx shut on/off. At the point of selling both of these new servos, radio system, and starting over Rather sell radio if needed...
Tried glitch buster, tested diff. servos, switches, and nothing. Never had this problem before, until I used this servo
Should I try Life-Po?
DX3S
SR300 and tried pro receiver
JR9100s
1256tg
Transponder
Nimh 5 cell 1400mah
drs92 is offline
Old 01-07-2012 | 02:37 PM
  #546
Hello,
I am planning to run a Savox 1267 in an RC8Be and was going to use a castle 10A Bec set to 7.4v. My question is whether I will still need a capacitor to eliminate any glitching while using a Spektrum SR300 receiver.
Thanks.
pede_187 is offline
Old 01-08-2012 | 02:58 AM
  #547
cwilkinson's Avatar
Was gonna buy another 1258tg for an scte but i think the 2271sg might be an even better option for $10 more dollars Has anybody ran this I cannot find much about it online
cwilkinson is offline
Old 01-08-2012 | 12:33 PM
  #548
I just stumbled on the sale they are having. It was $149, now $79. For that price, I couldn't resist it, so I have one on the way.
kazuaki is offline
Old 01-20-2012 | 06:22 PM
  #549
Seattlelife22's Avatar
does anyone know the screw size or link to the screws for savox servos? the horn screw.
Seattlelife22 is offline
Old 01-20-2012 | 06:27 PM
  #550
ozzy-crawl's Avatar
from memory there a standard 3mm screw or i should say bolt ?
Old 01-20-2012 | 06:29 PM
  #551
ozzy-crawl's Avatar
DX3S
JR9100s
1256tg
Transponder
Nimh 5 cell 1400mah
try a different battery pak, when using a seperate battery for rx/servos you should not need a glitch buster
Old 01-20-2012 | 06:30 PM
  #552
ozzy-crawl's Avatar
Originally Posted by pede_187
Hello,
Thanks.
with a seperate ubec you wont need a cap
Old 04-04-2012 | 06:06 AM
  #553
Big Will's Avatar
Can I run my 1256tg on a lipo without regulator?
Big Will is offline
Old 04-21-2012 | 12:29 PM
  #554
Are there any known problems with SC1268SG and Spektrum SR3100 DSM2 3CH Receiver when it is plugged to the throttle channel?
My problem is, when I turn the receiver on, the savox 1268SG makes a full turn to one side and then it goes back to the center position. As you can imagine this is not very helpful on the throttle/break side because it goes full the way to one side and this is much too long for my break.
When I but the savox on the steering channel it makes no movement when I turn the receiver on. The wired thing is, when I put my Vortex 2612HV on the throttle channel and turn the receiver on, it makes no initial movement and stays in his center position.
What I think, the savox 1268SG has a problem with the failsafe Mode of the Spectrum SR3100 DSM2 3CH Receiver. I set the failsafe server position to the neutral position but it didn’t change the behavior of the savox servo.
I also tried to reset and recalibrate my DX3R Pro but didn’t change anything.
xineohp is offline
Old 04-25-2012 | 05:33 AM
  #555
any ideas?
xineohp is offline
