Hobbywing Justock esc >
Like Tree4Likes
Old 06-06-2014 | 05:06 AM
  #121
Is a justock a good match for a 17.5 motor with a tc4? This is for a medium size outdoor track.
SouthFloridaApp is offline
Old 06-06-2014 | 05:50 AM
  #122
I'm battling.... I plug my Justock into the program box, confirmed V1_508 sw installed. I downloaded the new/updated sw, do I need to connect my esc to the box and the box to my computer in order to be able to update the sw?
SRJRacing is offline
Old 06-06-2014 | 05:57 AM
  #123
Yes
SteveM is offline
Old 06-06-2014 | 06:30 AM
  #124
liljohn1064's Avatar
Yes, you have to connect it to the PC via the USB port.
liljohn1064 is offline
Old 06-10-2014 | 12:15 PM
  #125
Good news for HW Just Stock ESC owners. USVTA has decided not to ban this ESC from VTA racing (see ROBK's post on the USVTA thread part 2) and instead opened up the list of approved ESCs to include those on ROAR's approved stock ESC's with ROAR approved Blinky (zero timing) software.
John Wallace2 is offline
Old 07-02-2014 | 03:51 PM
  #126
Hello, as you can get more power to the motor 10.5T in Spain sensors rotate a bit more and talk about degrees that shows a lower engine rpm and more.
this is true? as you do? have pics of how it's done?
a greeting
electrojer is offline
Old 07-02-2014 | 07:27 PM
  #127
Madulla's Avatar
No you can't add any timing on the JustStock. If that's what you are asking??
Something tells me google translate.
Madulla is offline
Old 07-03-2014 | 04:29 AM
  #128
hello, what I wonder is how you can give more to the engine timing?
Here in Spain revolve a little more sensors to run the engine
Old 08-01-2014 | 04:24 PM
  #129
Clawhammers's Avatar
Originally Posted by moparSRT
Yes there is, a replacment for the Justock, it was anounced end of April
Is there any update for this announcement ?
Clawhammers is offline
Old 08-01-2014 | 05:42 PM
  #130
Hello all I am having an issue with both of my used hobbywing just stock esc. When I hit the gas either nothing happens or it goes and when I let off it keeps going or cogs and stutters. This is with many different sensor wires that I know work ( tried them in my car) and I'm 5000% sure I soldered everything correctly as well as nothing plugged in backwards. What do you all think the problem is?
thecaptain is offline
Old 08-01-2014 | 07:15 PM
  #131
b20btec's Avatar
If you're positive motor and sensor wires are good you have to make sure the sensor wire is pressed in all the way on the esc. It needs to go in all the way or else the motor will cog.
b20btec is offline
Old 08-01-2014 | 08:51 PM
  #132
Grizzbob's Avatar
Super Moderator
Agreed, & additionally, you might need to try a different motor to see if it could be a bad sensor board on that, & if you try a motor you're 100% sure is good(works on other ESC's), then it could be the Justock itself...
Grizzbob is offline
Old 08-02-2014 | 04:04 AM
  #133
Everything works minus the just stock.
Old 08-08-2014 | 01:55 PM
  #134
SkiRideDrive's Avatar
Hey guys,
Complete electric RC newb here hoping for some advice. Planning on running a b5m in stock buggy. Here are the electronics I have chosen from my research.
hobbywing justock esc
Schurspeed 17.5
Promatch 2S 4800 MAH 90C Hard Case Shorty
Airtronics MT4S
Icharger 206B and Power Supply Ticket Combo
Regarding the electronics... I have never wired/soldered up a car like this. Any advice or links to how to's is much appreciated.
On promatchracing website, I can select a variety of female connectors, which should I pick?
Am I going to need to purchase any additional wiring to make this setup work?
Will I need any additional wiring to hook up the battery to the charger?
I appologize for my ignorance and thanks in advance for any tips or suggestions on what else I might need!
Thank you!
P.S. I plan on picking up a 40 watt soldering station, 60/40 solder, and some Rosin flux.
I also plan on getting the LED program card. Any tips on settings?
SkiRideDrive is offline
Old 08-09-2014 | 12:21 AM
  #135
lewis110's Avatar
Originally Posted by SkiRideDrive
Hey guys,
Schurspeed 17.5
Airtronics MT4S
Thank you!
All the wiring is there. I would suggest the LCD program box instead on the LED box.
lewis110 is offline
