Pro Trak
Old 06-15-2004 | 09:47 PM
  #76
JayBee's Avatar
Post
Originally posted by crimson eagle
Hi Jaybee,
I have a used one for sale right now, if you read a few posts down you can get the details.
A brand new unit, just the charger itself will be around $365.00 shipped. This does vary depending on the exchange rate though. The new version is getting close, 30A discharge and new case. The new ones have the blue backlit display also.
You can send me an e-mail if you like.
Thanks man, when are the new 30A ones coming out?
JayBee is offline
Old 06-15-2004 | 09:58 PM
  #77
JayBee's Avatar
Originally posted by V12
Phil the designer of the Protrak keeps an eye also on the small details. Some of them are not found with some of the other chargers.
-There are so much other features with the Protrak I´m not using but at least the above are important in my opinion and I really never had the feeling I bought the wrong charger.
i guess the problem with me is that i don't fully understand all of what the different features do to batteries, so it's getting pretty frustrating .
what about power supplies; i was thinking about the Bulldog 35A or 40A?
JayBee is offline
Old 06-15-2004 | 10:01 PM
  #78
JayBee's Avatar
i meant 30A or 45A?
JayBee is offline
Old 06-16-2004 | 07:09 AM
  #79
crimson eagle's Avatar
Hi Jaybee,
I'm told the 30A versions will be available at the end of July, these ones are a little more than the 20A versions $15 to $20 I think.
I use 15A power supply which works fine for me. The 30A discharge does not mean you are drawing 30A form the Power Supply, you are drawing 30A from the cells.
For more information on the the charging methods it's better to check out the Pro-Trak website, however generally when charging for racing I use linear, this seems to give good punch for when you are racing. For cylcling, I use soft pulse as this seems to help with the condition of the cells better.
Anything else I can help you with, just let me know.
crimson eagle is offline
Old 06-16-2004 | 07:13 PM
  #80
Barry White's Avatar
Seen These?
Barry White is offline
Old 06-16-2004 | 07:29 PM
  #81
Tres's Avatar
Company Representative
Yeah, he does a good job...
Here is one I did for the LHS with a Tony Stewart Theme....
Tres is offline
Old 06-17-2004 | 02:15 AM
  #82
Hi Guys
I have been using protrak for about 5 months now.I think it's the best charger at the moment.I'm using the multi phase charging system which is very good and i saw a lot of difference in the performance of the batteries.The ics is a very usefull tool which i uses a lot.Other chargers i don't think they have the multi phase charging.And the best thing i like in this charger is the support from the manufacturer.Phil is a great man with big patience and he always helped me out.
speed1 is offline
Old 06-17-2004 | 05:19 AM
  #83
Hi Speed,
Yes he is very patient, he has to be when he deals with me. I've never used the multi phase charging yet, what improvements do you see?
Old 06-17-2004 | 06:26 AM
  #84
kiyano's Avatar
Here is 30A pro-trak (ProtoType).
Not only discharge is possible with 30A, but the case became new.
There is a stand like a photograph, therefore the display became legible. The portion of a heat sink is covered in a new case. The case which covers a heat sink is not attached to ProtoType
Air cooling of the heat sink is carried out by four FANs
This case has quality higher than a old(current) case. A color is lusterless black
kiyano is offline
Old 06-17-2004 | 06:27 AM
  #85
kiyano's Avatar
more pic
kiyano is offline
Old 06-17-2004 | 06:31 AM
  #86
kiyano's Avatar
last pic
kiyano is offline
Old 06-17-2004 | 07:04 AM
  #87
Hi Kiyano,
Looks good, I hope to be seeing one soon myself.
Old 06-17-2004 | 07:49 AM
  #88
Hi Crimson
you will get a lot of punch for the first 3 min of the race.
speed1 is offline
Old 06-17-2004 | 08:08 AM
  #89
V12's Avatar
V12
speed1
what is your setup with the Protrak for the multi phase charging?
V12 is offline
Old 06-17-2004 | 10:46 AM
  #90
6A up to 2600mah and the rest 4A and .02 delta peak.3300 cells.
speed1 is offline
