NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 04-13-2015 | 07:34 PM
  #12166
mocrawlin's Avatar
I am getting a hw just stock esc later this week. I'm pretty sure it includes a programmer also. My question, is this just 2s capable? Or will it go 1s also? Don't really think I will ever run 1/12th but who knows. LoL
mocrawlin is offline
Old 04-13-2015 | 07:59 PM
  #12167
I'm using one in my 1/12th scale currently,pulled the red wire, leaving the power switch off and using a reciever pack.
noproblems209 is offline
Old 04-14-2015 | 09:31 PM
  #12168
mocrawlin's Avatar
When you say pulled red wire? On the reciever plug? And how does it work with switch off? And how do you aet you voltage cutoff? I thought it would not work because the esc would shut down because it saw less than 6v.
Old 04-17-2015 | 03:40 AM
  #12169
COBRARACING's Avatar
Some new racing products coming
keep you posted.
COBRARACING is offline
Old 04-27-2015 | 12:40 PM
  #12170
Come on Angelo, spill the beans! Is the android app coming?
sleenad is offline
Old 04-27-2015 | 08:06 PM
  #12171
Madulla's Avatar
Angelo's can has had beans in it for about 8 months now... Still waiting for the JustStock V3 announcement.
Madulla is offline
Old 04-30-2015 | 01:18 AM
  #12172
EDWARD2003's Avatar
Ignore this post
EDWARD2003 is offline
Old 04-30-2015 | 05:56 AM
  #12173
S.Stew's Avatar
I've used a Just-Stock in 17.5 12th scale without a booster or receiver pack. It might depend on your receiver and servo though, as some work better than others at lower voltages.
S.Stew is offline
Old 04-30-2015 | 06:24 AM
  #12174
Dan's Avatar
Dan
I know someone running it on 1s. They are using a booster for the receiver and had to disable low voltage cutoff.
Dan is offline
Old 04-30-2015 | 05:29 PM
  #12175
Hi guys, I have Xerun 60A v2 esc and my Hobbywing USB Link v3.50. What software should I use to run stock with boost and timing? Many thanks.
rccartips is offline
Old 04-30-2015 | 09:16 PM
  #12176
EDWARD2003's Avatar
I've bought a Hobbywing V3.1 for touring and I'm thinking of running 1/12th 1s modified (3.5). Now, I've come across a Sanwa servo that runs specifically on 3.7v Part# 107A54201A. Would this servo in combination with Hoobywing V3.1 elminate the use of a booster?
The receiver is a KO Propo KR-411 FH.
Old 05-12-2015 | 10:09 AM
  #12177
macdude's Avatar
I think you would still need a booster. As the receiver needs more than 4.2 volts. Looks like it is spec at 4.8-7.4. Running 1 cell you will not get close to that.
macdude is offline
Old 05-12-2015 | 10:25 AM
  #12178
YoDog's Avatar
Just get a 1S ESC and be done with it...
If money is an issue, go for the TrackStar 1S model and a programming card. all together plus shipping, the cost is less than $100.
YoDog is offline
Old 05-12-2015 | 06:56 PM
  #12179
EDWARD2003's Avatar
Money is not an issue. I just want to utilize the Hobbywing V3.1 120A for both touring and 1/12th racing. I don't want to have a 1s specific esc which is limited to only 1s. Found a booster and all is good
Old 05-12-2015 | 07:06 PM
  #12180
theproffesor's Avatar
So... It's been about a month, still waiting on the good stuff
theproffesor is offline
