NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 01-28-2013, 03:09 AM
  #10501
TryHard's Avatar
Originally Posted by Holmenkollen
Anyone with a good V3 setup with SP 4.5t? Indoor carpet. I´m lost in the setting djungle....
Can try this, maybe tone it down a bit for indoor though (just use less boost&turbo)
FDR - ~8.2
General setting
1A Running mode - Fwd/Brake
1B Reverse - 25%
1C Cutoff Voltage - 3.0v
1D ESC Overheat - 125°C
1E Motor Overheat - 125°C
Throttle Setting
2A Punch Rate Switch Point - 50%
2B 1st Stage Punch rate - 12
2C 2nd Stage Punch rate - 15
2D TH Input curve - Linear
Brake Setting
3A Drag Brake - 10%
3B Brake Strength - 62.5%
3C Initial Brake - Drag Brake
3D Brake Rate Switch Point - 50%
3E 1st Stage Brake rate - 20
3F 2nd Stage Brake Rate - 20
3G Brake input curve - Linear
Boost
4A Boost Timing - 26steps
4B Boost Start RPM - 11,000rpm
4C Boost End RPM - 27,500rpm
4D Boost Slope - Linear
4E Boost by Throttle - Yes
Turbo
5A Turbo timing - 24steps
5B Turbo Activation - Full TH
5C Turbo Full TH Delay - 0.15s
5D Turbo Start RPM - 20,000rpm
5E Turbo engage slope - 18steps/0.1s
5F Turbo disengage slope - 18steps/0.1s
As I mentioned, for indoor carpet, I would look at dropping boost to around 20-22, and turbo maybe down to 18 to start with. If you need it a bit more aggressive, turn off Boost by throttle, and also drop turbo engage to 0.1. All very dependent on track though, but those are the settings I tend to alter when tuning to a new track.
Hope that helps.
Ed
TryHard is offline
Old 01-28-2013, 03:33 AM
  #10502
Holmenkollen's Avatar
FDR - ~8.2
General setting
1B Reverse - 25%
Throttle Setting
Brake Setting
3A Drag Brake - 10%
Boost
Turbo
Hope that helps.
Ed
Thanks! I will try it. What ESC temps are you getting with this seetting? What is considered to be ok?
Holmenkollen is offline
Old 01-28-2013, 09:38 AM
  #10503
j.d.roost's Avatar
Trader Rating: 32 (100%+)
Need a good v3 17.5 blinky setup with the latest software.
I switched from a tekin and the brakes on this thing seem very weak.
Hoping I missed something...
I searched and can't find what I am looking for.
Any help would rock.
j.d.roost is offline
Old 01-28-2013, 02:05 PM
  #10504
Trader Rating: 90 (100%+)
Do you run offroad blinky? Do you have the programming card? You'll have to load the v3_508 firmware for blinky. While you're at it, change DDRS punch setting to 9 if you have high C rated batteries. I also increase the brakes to 100% (esc) and use my radio to lower my brake EPA to feel.
The hobbywing ESC's are much smoother than the tekin's light switch feel.
Kuya_Kimo is offline
Old 01-28-2013, 05:16 PM
  #10505
COBRARACING's Avatar
Hi Guys
There are two companies that have copied the v3 esc from us i cannot mention their names for legal reasons but i can tell you the following
We have only oem the v3 esc to the only two following brands
HPI and Yokomo
There are no other companies that we have oem the v3 to so be careful what you buy and from who you buy from .
COBRARACING is offline
Old 01-28-2013, 05:28 PM
  #10506
LOW ET's Avatar
Trader Rating: 109 (100%+)
so this place is not legit anymore? http://www.falconsekido.com/
LOW ET is offline
Old 01-28-2013, 05:30 PM
  #10507
narcotiks's Avatar
When is the xerun v3.1 firmware going to be available for download? I assume it is compatible with the v3?
narcotiks is offline
Old 01-28-2013, 05:43 PM
  #10508
TCCustoms's Avatar
yes, they are legit but they are a dealer...the 2 brands he named are RC Car manufacturers, NOT dealers
TCCustoms is offline
Old 01-28-2013, 08:02 PM
  #10509
ByteStream's Avatar
I don't foresee a new version of software for the v3.1 .. It has an aluminum bottom case and has been made a little more dirt-proof and that's about it from what I have read. The latest firmware for the v3 is pretty solid.
ByteStream is offline
Old 01-28-2013, 08:29 PM
  #10510
This is the North America reseller for Hobbywing, I suggest buying all hobbywing items directly from here to get your 6 month warranty.
Old 01-28-2013, 09:22 PM
  #10511
j.d.roost's Avatar
High grip-indoor carpet-blinky-touring car.
I do have the card and pc interface software.
I can see the brakes being more than enough for offroad..Just a bit soft for the needs of carpet touring car (as compared to the rs). Again I may be missing a few settings in setup. I will post my current setup later today.I know anything to do with brakes/punch are at their highest setting...and from what I recall I am running the latest software in the esc.
edit*settings
mode 2-zero timing
forward/brake
reverse speed 100%
v.cutoff-disable
esc overheat-off
motor overheat-off
pr switch point 50%
1st punch 30
2nd punch 30
th curve linear
neutral range 4%
drag brake 0%
brake strength 100%
initial brake 0%
brake switch point 50%
brake rate 20
2nd brake rate 20
brake curve linear
Old 01-29-2013, 04:17 AM
  #10512
lewis110's Avatar
Put your initial brake to 20%... Have you tried any drag brake? I like to use about 10% with my stuff.
lewis110 is offline
Old 01-29-2013, 04:52 AM
  #10513
j.d.roost's Avatar
I don't usually mess with drag brake..For me it's hard to use when you need a few moments of "coast" on a particular layout.Although other drivers
I know love it.
I will mess with that initial brake setting.
Do the other settings look good for 17.5 tc/carpet?
Old 01-29-2013, 05:28 AM
  #10514
lewis110's Avatar
I know love it.
I will mess with that initial brake setting though.
Yeah, the other settings look ok to me. I always keep overheat protection on, but that's a personal preference.
lewis110 is offline
Old 01-29-2013, 09:52 PM
  #10515
Aravan's Avatar
Anybody got a good base setup for a 120A 1s with a D3.5 17.5t boosted in a 12th scale indoors? Guessing 930stock will be the best firmware to run?
Aravan is offline
