NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 12-17-2012, 11:13 AM
  #10336
Barry_Hughes's Avatar
Originally Posted by ScottyTC4NZ
HELP
What motor?
Makes a big difference to the settings
Barry_Hughes is offline
Old 12-17-2012, 08:02 PM
  #10337
ScottyTC4NZ's Avatar
Originally Posted by Barry_Hughes
What motor?
Hi Barry
Running a V3 with a HW 21.5t Xerun Sensored
Open timing
ScottyTC4NZ is offline
Old 12-18-2012, 11:42 AM
  #10338
I would run a FDR around 5
boost 40
rpm start 1,500
rpm end 12,000
boost by thr No
turbo 24
turbo activation Full Thr
turbo eng 12/0.1s
turbo disengage 6/0.1s
turbo delay 0.2s
boost & turbo linear
thr punch rate switch 50%
1st stage 20
2nd stage 30
keep an eye on temp
Old 12-20-2012, 10:57 AM
  #10339
Hi , searched but didn't find nothing conclusive ,
I have a Venom PRO Brushless 120A esc and it looks just like xerun 120a sd , but is green.
I've read in some posts in this forum that this Venom esc are the same as Hobbywing xerun 120A ,
is it true ??
and can I use the hobbywing lcd program box, and this supercharger firmware in the venom esc ??
BL4x4 is offline
Old 12-20-2012, 03:57 PM
  #10340
COBRARACING's Avatar
is it true ??
yes very true and you can use the programmer and the software
COBRARACING is offline
Old 12-20-2012, 03:59 PM
  #10341
Merry Xmas from the crew at hobbywing .
Attached Thumbnails NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-2012-_121219.jpg
Old 12-21-2012, 01:48 PM
  #10342
Trader Rating: 90 (100%+)
My bad HW 120amp ESC appears to work again on the bench with the v3.1 software v3_508_NoTiming software and NO reverse. I haven't tried it on the track or on a car.... but if you run into issues with your ESC and the new v3.2 software.... try v3.1 again (v3.2 didn't un-install v3.1 during it's installation).
Originally Posted by Kuya_Kimo
Looks like I've had my first issue with a hobbywing ESC (HW Xerun 120a 1s ). The HW ESC Sensor port apperas to have gone bad right before my A-Main which I TQ'd. The ESC will power on but the ESC will not turn.
For troubleshooting, I have tried different sensor cables, unplugged the sensor cable all together (turns but cogs), rebound my TX to ESC, tried a different motors, and have even tried to reload the firmware without any success (both motors and sensor cables work perfectly with another ESC).
It was plugged in a TLR 22sct, 17.5 motor, 2s 65c rating battery, and I was able to complete both quals with success. When I powered on for the main... the motor would not start then my troubleshooting began. (version v3.2 software).
My HW lineup includes: Xerun 120a 1s, Xerun 120a v2.1, Xerun 60a v2.1, SCT-Pro
Kuya_Kimo is offline
Old 12-24-2012, 10:42 PM
  #10343
Originally Posted by COBRARACING
Hi Guys i am going to do some setup sheets for the following v3 and 2.1v
Motors 4.5T 5.5T 8.5T 11.5T 13.5T 17.5T 21.5T
These will be basics sheets to get you started but will also perform as they should .
Have the basic setup sheets been done yet? im after a starting point for a 21.5 on 930stock
thefan is offline
Old 12-24-2012, 11:08 PM
  #10344
AdrianM's Avatar
Can you please release a 1s version of the V3 speed control? It would be great to have a smaller controller than the current Xerun 1S with a built in booster BEC.
AdrianM is offline
Old 12-26-2012, 03:16 AM
  #10345
What Motor?
Old 12-26-2012, 06:54 AM
  #10346
Sorry if this has been asked before.
Are the Turnigy Trackstar Turbo ESCs (120A & 80A) copies of the V2 Hobbywings ESCs??
Can I use the Hobbywing Programming card and PC software on these two ESCs (the Trackstars).
Thanks.
Serpenteer is offline
Old 12-28-2012, 09:14 AM
  #10347
ByteStream's Avatar
+1 .. Any update on the 1S V3?
ByteStream is offline
Old 12-29-2012, 07:30 AM
  #10348
Hi guys
I cannot promise a release date but i can tell you that the esc will have built in caps to save room in you 12th scale pan cars.
The esc is complete just testing at this present time a few little bugs to sort out.
Old 12-31-2012, 12:07 PM
  #10349
how do you get the software to the box from web site
to slow for you is offline
Old 12-31-2012, 01:14 PM
  #10350
TCCustoms's Avatar
Using the cable provided with your esc, you hook it up to your computer and plug into the spot on programming box, and hook up your esc to the box(not needed if just upgrading the box)
Go to Hobbywing.com site and download the software for your computer, You will need a zip file extractor to open file, run the application software once unzipped and it will install....
Check HERE FOR LINK...its the link to hobbywing where you download the software and then click the Manual tab for instructions you can download on how to do so if your still not sure
TCCustoms is offline
