NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#9677
Boost/turbo functions will not work with a sensorless motor
Use gearing to get desired performance. Upgrading to a sensored motor and using boost/turbo would make a MASSIVE difference, especially if your using the 'finned' can ezrun motors
#9679
Anyone having issues with errors occuring from trying to remove or upgrade sp software or orion from their Hobbywing esc's please let me know i can help you solve the issue without having to downgrade to older version to fix the problem .
But please in the future dont load sp or any other software on the hw esc's .
regards Angelo
regards Angelo
#9682
#9684
i bought a xerun 120a esc with 2in1 program box.
So my latest version for the esc is: V3.0_110930_MOD
and for the program box is: V1.08_120504 (i didn;t put the version V1.1_120331 because i read that is for V3 esc )
Those are the latest, or i don't have the latest firmware?
thank you
thank you
#9685
Yes you have, but the firmware in the ESC is for Modified motors.
If you are going to run STOCK motors, and want to use boost timing, upload V3.0_110930_STOCK to your ESC
#9686
#9687
Hello,
I have a Hobbywing 120amp 1S esc. I need it to run with no timing. From what I have seen elsewhere, when the no timing software is programmed into the esc, the red light is supposed to blink. WELL, MINE DOES NOT!!!!!
I have tried firmware versions v3.0_110930STOCK and when I try to run the car with a 1S pack, it blinks the light which from what I can see means low voltage. If I hook up a 2S lipo it runs, but does not blink.
I have tried firmware version v3_508_NO timing. This works with a 1S lipo, however it does not blink to indicate that the timing is turned off.
What version of the firmware do I need to use to be compatible with a 1S lipo and have the light blink to indicate that the timing is turned off?
thanks,
tim
thanks,
tim
#9688
Hello,
thanks,
tim
thanks,
tim
You should be using v3_508_NO timing. Make sure to recalibrate the speed control after you update. If you don't get your answer here, stop by the track and I can take a look at it.
#9690
I do have one thing that's still not clear to me. The software has 3 different "profiles" that can have different settings in them. Are these profiles stored in the ESC or in the program box?
