NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 06-12-2012, 02:24 PM
  #9241
NR
NR's Avatar
Trader Rating: 52 (100%+)
Originally Posted by hyujmn
Ok, time for an update.
Just tried switching pretty much every part around on the motors. Switched out rotors, switched out sensor boards, switched out sensor cables. I've got basically 2x Revtechs and sensor cables and rotors. I've tried every combination of all the parts. Rotor A with Sensor Board A with Sensor Cable A. Rotor B with Sensor Board A with Sensor Cable A, etc etc etc...
Still nothing. It does the same crap as always. Now, I did notice that the first time I fixed it, it had something to do with the sensor cable. Is it possible that I just have absolutely rotten luck and both of the sensor cables I have are faulty? that seems pretty harsh, especially if I just spent the whole night figuring this out...
I had the same problem, and it only gets worst, and according to Angelo it's a software malfunction and new software needs to be loaded on to the ESC, once this was done on mine, the problem has been fixed and not occurred again.
Angelo perhaps send this guy the same software upgrade you sent me.
It sounds very similar to my problem, mine uses to stop start and go slow then kick in.
Best of luck, and rest assured it's nothing to do with the equipment, I went through the annoying task of double checking everything also.
Regards
Nathan
NR is offline
Old 06-12-2012, 03:17 PM
  #9242
COBRARACING's Avatar
The problem is that I've taken a known working sensor cable that I've been using on my vta car and it still didn't work. I'll try a few others tonight. Gonna have to borrow some from my brother.
Send me an email and ill help you [email protected]
COBRARACING is offline
Old 06-12-2012, 04:00 PM
  #9243
Trader Rating: 27 (100%+)
For some reason it's saying email address does not exist. I just tried to email you.
hyujmn is offline
Old 06-12-2012, 04:27 PM
  #9244
B4james's Avatar
Try the email address as
[email protected]
B4james is offline
Old 06-12-2012, 04:55 PM
  #9245
yokemad's Avatar
Hobbywing Usb link v3.1 download link gives error 404
is there anywhere else to download this ?
V1.64 not works I tried to run it as Admin on Win7 (used to work but not anymore)
Cheers
yokemad is offline
Old 06-12-2012, 11:31 PM
  #9246
etivac13's Avatar
Trader Rating: 10 (92%+)
Cheers
http://www.falconsekido.com/pages/download
etivac13 is offline
Old 06-13-2012, 02:15 AM
  #9247
blade072's Avatar
Trader Rating: 98 (100%+)
mmmmmm shiny.....
Attached Thumbnails NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE-hwv3-large-.jpg
blade072 is offline
Old 06-13-2012, 02:55 AM
  #9248
ta04evah's Avatar
Originally Posted by etivac13
Thanks for that, always good to have an alternative site to download from.
Cheers
Rob.
ta04evah is offline
Old 06-13-2012, 05:17 AM
  #9249
kermit's Avatar
Originally Posted by blade072
mmmmmm shiny.....
Please share
kermit is offline
Old 06-13-2012, 05:20 AM
  #9250
blade072's Avatar
Originally Posted by kermit
Please share
COME GET ONE!!!!! ill even throw in a cap for the pins
blade072 is offline
Old 06-13-2012, 05:55 AM
  #9251
Default v3 modified settings
hi guys,
i am running 4.5T thundepower motor in modified. got the new v3. any tips on settings? there seems to be a "default modified" programm set on the speedo? is that safe to use. or do you guys change stuff.
//edit: found it. thx. i will stay with default settings and a 8 FDR for starters.
vitomon is offline
Old 06-13-2012, 05:57 AM
  #9252
yokemad's Avatar
Thanx Mate
yokemad is offline
Old 06-13-2012, 08:22 AM
  #9253
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by artwork
Cobra-
Can you please provide some insight here...is there settings that can be changed to improve the feel of drag brake?
The issue is not much about how much, but more about how the drag brake is applied.
Thanks...
Bump.
Any comment on the drag brake issue before I sell the V3 and start telling everybody it sucks?
syndr0me is offline
Old 06-13-2012, 10:10 AM
  #9254
RasCalDK's Avatar
Originally Posted by vitomon
hi guys,
The standard program is fine, no problems there.
I have, with help from a mate, changed the Boost settings and added Turbo.
Here is a link to download the PDF setupsheet(the file was to big to upload):
https://dl.dropbox.com/u/31035638/4....-%20Odense.pdf
On the fast flowing track i tested, the temps were actually the same with the added boost and turbo, as with the standard modified program on 7 min runs.
I geared from 8.00-8.30 and the endbell timing from 5-10 deg.
The changes gave more power and topspeed, but still had a smooth linear feel.
RasCalDK is offline
Old 06-13-2012, 10:29 AM
  #9255
bkspeedo's Avatar
Originally Posted by syndr0me
Bump.
Why are you using drag brake? Real drivers know how to use brakes from the remote. LOL
bkspeedo is offline
