NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#5656
Saw it, looks gooood.
Well done to Brian on his result, his car was super dialed all weekend. Quick aswell!
There were quite a few Hobbywing ESCs in mod and in Pro-Stock. My result was nothing to shout about but I was very pleased with the Xtreme stock when I had my 1 dry run of the weekend!
OK am going to have a mad moment here.............
To celebrate Brian's success gonna do something mad with the xtreme Stocks...........
Pizza Hut style..........
Till 3pm Friday 22nd July 2011 Extreme stocks are Buy one get one 1/2 Price !!!!
PM me for the voucher code if you want to take me up on my madness !!!!!
#5657
I just got an Xerun 60a with the 211 firmware on it.
It's running a Hacker 17.5t motor, I havn't got a sensor cable for it yet (in the next parts order).
When moving around slowly and I go for a full throttle pull it cuts out for about a second, anyone know what causes this?
Is it because it doesn't have a sensor cable on? (seems to run fine other wise though and cogs less than my ezrun 60a).
Batteries are fine, setup is fine so I can't think of anything else that could cause it.
I do have it in a stadium truck and have turbo etc off (I think, still trying to figure out the settings) and running 12 degrees timing.
#5658
Shawn.
#5659
If I slowly roll onto the throttle it's fine.
From a dead stop and go full throttle it's fine.
It's just at a certain speed (just moving) and I go to full throttle it cuts out.
I probably shouldnt be grabbing full throttle like that but the motor has a horrible power curve, about the first 1/3rd of throttle its gutless and doesn't really wanna get up and go but once it gets past that it comes on hard then is fine till full throttle.
I just grab full throttle to get it moving.
I just tried another motor aswell and it doesn't do it, but it's a 4 pole 2930kv motor which is very smooth and rarely ever cogs.
My hacker cogs really badly, can't wait till the sensor cable gets here.
#5660
#5661
#5662
#5663
It's just the 6 pin cable.
I'll just wait till the cable gets here before I will say theres a problem with it.
#5665
capability of xerun 60a
I need a speedo for my new 1/10 off roader, and it may also be used in my 1/12 car.
I was considering getting the xerun 60a - I already have a xerun 120. I am just a bit strapped for cash, and wanted to know if the xerun 60a can run 211 safely with motors up to 10.5 at a similar performance level to my 120a version
#5666
#5667
if running a 5.5t motor with a xtremestock esc, should i use no timing software, or can i use a older mod software an use normal timing on the motor? (no turbo or boost)
use 8.5t motor with 119 mod software, the speed is there, but have a 5.5t here and want to see how it feels and how the temp is compared to a "slower" and boosted motor.
using a 120a today but there is so little space in my car (ta06) and the xtremestock fits perfectly!
#5668
another question about speed / motor heat
what generates less heat, more gearing and less turbo/boost OR less gearing and more turbo and boost?
#5669
#5670
213 software
Cherry2blost, i see you're quoting that you have the 213 software. I cant see it on the Hobbywing site. How and where did you get it?
