NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#4757
the instructions say to turn on the transmitter...hold the set key....turn on the speedo....hold set key until red light begins to flash and relaease immediately. tried this numerous times...different batteries....motor hooked up and not hooked up...different motors....always the same....red light stays lit constantly and speedo will not calibrate to radio.
#4758
I do mine by;
1. With transmitter on and binded to the receiver, hold the red button WHILE switching ON the ESC.
2. The ESC should be beeping now, let go the red button. Now press it once to register the neutral position (it'll beep once).
3. Pull the throttle to maximum, hold it right there, and click the red button to register the maximum throttle position. ESC should beep twice.
4. Push the throttle to maximum, hold it right there, and click the red button to register the maximum braking position. ESC should beep 3x.
I hope it works out for your
#4759
In case it differs,
I do mine by;
I do mine by;
#4760
#4761
#4762
Hold the set key, turn on the speedo, after 1 sec, release the set key....
#4763
can any of the hobbywing guys tell what the the mechanical timing is fixed to on the 13.5 xerun motors , i use one of the older dark blue ones.
#4764
How is the ROAR approval coming on the Hobbywing motors? Has Hobbywing submitted an Xerun esc for ROAR sportsman class approval yet?
#4766
#4768
#4769
21,5T ,17.5T,13.5T 10.5T 8.5T 6.5T 5.5T 4.5T 3.5T
2000kv and 2250kv for 1/8th scale
and 120 amp ,xtreme stock and justock also have been submitted for zero timing sportsmans class.
regards Angelo
#4770
All is complete from motors to speed controllers just waiting for the list to be updated .
regards Angelo
regards Angelo
