NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#316
518 software!!
To Hobbywing:
What are the differences between the new 518 stock software and the "old" 422 software? I did see it said to fix some bugs - can you please expand on that if possible
For anyone interested: http://www.hobbywing.com/english/downloads.asp
Thanks very much
Michael Jones
Thanks very much
Michael Jones
#317
Hi Guys
Anyone tried one of HW 13.5 motors, if so how do they compare with say a Duo 2, GM, etc
Cheers Malc
Cheers Malc
#318
To Hobbywing:
Thanks very much
Michael Jones
Thanks very much
Michael Jones
#320
#321
The new firmware for ESC and LCD program box is released:
http://www.hobbywing.com/upload/soft....62_100520.rar
What is new in this firmwares package:
1) 100518Stock Firmware for supercharged stocking
It is an improving version of 100422Stock firmware for XERUN-120A and XERUN-60A ESC (V2.0 or V2.1)
2) V1_0508_No Timing Firmware
It is suitable for XERUN-120A and XERUN-60A ESC (V2.0 or V2.1). It disables all timing functions. All the timing setting are NOT changable, they are permanently set to zero by Hobbywing. And the red LED blinks when in neutral. This firmware is compliant with ROAR 2010 rulers about the Sportman group ESC
3) V1.06 Firmware for LCD program box
After updating your LCD program box to this new firmware, when the LCD program box is connected with the ESC, the firmware version of the ESC can be shown on the LCD. With this new function, it is much easier to check the current firmware version of your ESC.
This improvement comes from the suggestions of our customers and friends. Thanks very much !!!
4) 100324_3R Firmware
It is used for XERUN-80A and XERUN-150A ESC of 1:8 scale cars.
#322
And ill keep an eye on this thread over the next few days if someone can try doing some testing and tell us all what they think
#323
The bugs in the 0422Stock firmware:
1) If the Start Model (Punch) is set to an option less than "Level 6", the motor cannot get its full speed.
2) When the car runs into a big curve, the turbo function may be shut off when the throttle stick is closed, and the turbo function wil be activated again after 0.x second (=Turbo delay time), that makes the motor cogging, so the motor cannot run very smoothly.
The new firmware (100518Stock) hasn't the above bugs and improves the control feelings.
#324
#325
#326
Mr. Hobbywing,
PM has been sent to you.
Thanks!!
Thanks!!
#327
Thank hobbywing for the detail explanation ..
#328
@Hobbywing:
I have a suggestion for future firmware version. I'd like to add an additional Timing Punch option for Turbo Timing. This way Boost Timing and Turbo Timing can increase at different rates. Example: Boost Timing can be increased 1deg. every 400rpm and Turbo Timing can be increased 1deg. every 200rpm. This way we could achieve different acceleration characteristics on the infield and on the straight.
#329
Does anyone ever use the first couple options in boost timing (item 9)? Unless people are actually using these low boost setting, they seem useless. It'd be nice to see everything shifted up.
Example:
1) 0 deg (Off)
2) 9 deg
3) 12 deg
4) 15 deg
5) 18 deg
6) 21 deg
7) 24 deg
8) 27 deg
OR if people use options 2 and 3 then maybe add option 9 and 10.
I'd rather have too much than just enough to work with. Same thing with Turbo Timing. 1deg, 2deg and 3deg just don't seem like enough to be useful. I'd like to see these settings shifted up a bit too.
Example:
1) 0 deg (Off)
2) 9 deg
3) 12 deg
4) 15 deg
5) 18 deg
6) 21 deg
7) 24 deg
8) 27 deg
