Binding a DX2 to SR3000 >
Old 08-05-2009 | 04:21 PM
fvrr's Avatar
Default Binding a DX2 to SR3000
I have a new DX2 I got for my daughter and a used SR3000. The radio seems to bind fine but the rx just has a quick flash of green and nothing else. I've tried it with a bind plug and without. If it make a difference it's in a stock slash.
fvrr is offline
Old 08-05-2009 | 06:07 PM
A quick flash of green when powering up the receiver, then nothing? That’s what I have seen when the esc is plugged into the receiver backwards. Is the black wire towards the outside of the receiver case?
Dave H is offline
Old 08-05-2009 | 07:02 PM
RCGaryK's Avatar
SR3000 doesn't use a bind plug it has a bind button.
Make sure you have your polarity correct too with the plugs. I know on the SR3500 if you have the ESC or receiver pack plugged in backwards it will flash twice, pause, flash twice, pause. Haven't run into that issue with the SR3000 but then again it's been 3 years since I've run one.
RCGaryK is offline
Old 08-05-2009 | 07:29 PM
Oops, I was mistaken. I just tried a SR3000 backwards. Got a repeating double flash just like Gary.
Dave H is offline
Old 08-05-2009 | 09:36 PM
fvrr's Avatar
No double flash just 1 quick flash. Looking at the rec the ground (black) wire on the right. So I'm guessing hold the blue button down before powering up the truck. Then hold the button on the back of the radio while turning on the radio with you toe I'll try to reverse the wires to see if I get the double blinking.
SWEET, just tried what I just said above. I never tried to hold the button down before powering up. DONE! Thanks for the tips.
fvrr is offline
