duo 2
Old 08-03-2009 | 09:26 PM
Default duo 2
To change the timing on the new duo motors do the three philips head screws need to come out or the screws that go the shaft side? I thought i read somewhere the timeing could be changed with aout removing the motor. thanks you for the help.
chris
chrisw is offline
Old 08-06-2009 | 01:25 AM
loosen the three screws, turn the inner part off the endbell to your desired timing, then (not too tight) tighten the screws. Voila
trigger is offline
