Futaba receiver question
#16
hey,
i am currently running a 3pm 2.4ghz with a R603FF, and Ive run it in my slash with great success, no overheating problems but now need another one, so will a R603FS work on the 3pm too?
Also because the slash has such a tiny radio box (since it only houses the reciever) does anybody think i'll have overheating problems? I reckon i should cut some plastic out the reciever casing as they are easy to open up.
Cheers.
Cheers.
#17
hey,
Cheers.
Cheers.
The heating problems came form inside the receiver, voltage regulators! Not to worry about operational temps unless they get above 150 degrees.
#18
This is a bit off topic, but couldn't you guys run regulators like when you run a lipo in a nitro car? that way, the servos connect direct to the lipo so you aren't relying on your receiver for all the power. Just a thought.
#19
The receiver has to power the servo(s). I've read that you could put a low mah lipo to a reveiver tho.
#20
The only wires that need to go to the receiver are the signal and ground wires.
You make the ground into a Y harness and take the positive for the servo directly to the regulator.
A pos/neg will need to come out of the regulator and go to the receiver battery port as well.
