Keyence ESC
Old 08-12-2004 | 02:25 PM
  #106
JayBee's Avatar
Post
sorry here it is.....
JayBee is offline
Old 08-12-2004 | 02:29 PM
  #107
JayBee's Avatar
Post
here's a better pic... anybody got any pics of they're electronics layout?
- jAyBee
JayBee is offline
Old 08-12-2004 | 02:42 PM
  #108
coastaltony's Avatar
JayBee that is a real
nice looking paintjob.
Here is a picture of my layout. I just had to get a "Hara Twister" for my Pro 4, so this Zero Extreme is for sale.
http://pic13.picturetrail.com/VOL466...7/62810761.jpg
coastaltony is offline
Old 08-12-2004 | 02:46 PM
  #109
Originally posted by
heathcliff
Hi guys, wat are the differences
between the keyence zero v extreme and
the 2002 version?
What improvements did they make on the
new rapida over the zero v extreme?
Is it still worth getting a zero v
extreme?
Cheers.
I asked AdrianM from Schumacher that question today and he said they are the same, with different labels on them.
Old 08-12-2004 | 03:26 PM
  #110
JayBee's Avatar
Post
A couple of questions before I put the Keyence in...
#1) Is the heatsink necessary? All I will be running is STOCK @ this point, and..
#2) Is the heatsink as effective if I wanted to mount it to the side opposite to the left/right function indicators?
I guess there's 3 questions,
#3) If I use SHOEGOO, will it conduct heat sufficiently from ESC- heatsink?
- jAyBeE
JayBee is offline
Old 08-12-2004 | 05:05 PM
  #111
AdrianM's Avatar
JayBee:
No, I run Mod and I dont run a heat sink.
No, to mount the heatsink you must remove the name plate badge and adhere the heatsink to the FET heatsink plate underneath.
Shoo goo is fine as long as its a VERY thin film. The double sisded tape (not servo take but thin double sided clear tape) is the best thin to use. if there is any thicknet to what you use to mount the heatsink you might as well not put it on.
AdrianM is offline
Old 08-12-2004 | 05:39 PM
  #112
OB42TC3's Avatar
Registered User
Is there anything that can go wrong with the 2002 that would cause it to arc the brushes in a mod touring car excessively(like completely burning up the bruhses till they turn silver?) It was fine the one week then this happened the next week with two different motors. Could the esc have been damaged by not running a schotky or the special keyence capacitors? Any way to test the esc?
OB42TC3 is offline
Old 08-12-2004 | 05:44 PM
  #113
JayBee's Avatar
Thumbs up
Originally posted by AdrianM
JayBee:
Hey AdrianM,
Long time- no hear from; if you remember, I contacted you awhile back about this Keyence. You didn't have any in at the time but I managed to find one and here I am as promised to ask YOU for help . I'm not at that point right now but just giving you a heads-up.
- jAyBeE
JayBee is offline
Old 08-12-2004 | 06:57 PM
  #114
JayBee's Avatar
WHAT'S THIS?
Anyone know what the HECK this little 2" yellow wire is for?
JayBee is offline
Old 08-12-2004 | 07:24 PM
  #115
i think the yellow wire is used if you have a FET servo. the wire gives it 7.2volts for power, instead of being stepped down to 6 volts.
marvi is offline
Old 08-12-2004 | 10:48 PM
  #116
JayBee's Avatar
Thumbs up
ALL DONE!!
Alright, I'm all done installing the Keyence, getting the wires all out of eachothers way (as much as I could), and trying to make it all look good at the same time. I have to admit though, I'm pretty freaked out to turn it on to start programming it. Being in this hobby only about 7 mnths, reading the manual on this thing was overwhelming.
So what's the 1st thing I should do? I don't know if this matters, but I'm running a pretty simple radio- JR's XR2i. I'm going to be running stock, but none of the settings in the manual goes into 27t.
ANY AND ALL HELP IS NEEDED AND MUCH APPRECIATED
- JaYbEe
OH BTW, should I cut off the little yellow wire
JayBee is offline
Old 08-12-2004 | 11:05 PM
  #117
JayBee's Avatar
Do I need to install the three CAPS that are included with this ESC?
- JaYbEe
JayBee is offline
Old 08-12-2004 | 11:24 PM
  #118
HelpWanted's Avatar
Registered User
Try the factory setting #5 for stock.
Those capacitors are for your motor. Since you are running that Epic motor, you won't be needing the caps. That motor have caps installed. I'm sure you already knew that.
I would leave the 7.2V lead alone.
Enjoy,
HW
HelpWanted is offline
Old 08-12-2004 | 11:25 PM
  #119
Originally posted by JayBee
[B...OH BTW, should I cut off the little yellow wire [/B]
i suggest you dont cut off the wire. i use the zerov extreme in my evo3. i just put a small heatshrink tubing on the tip (to prevent it from accidental fraying) and then wound it along with the red/black wires for the on/off switch.
marvi is offline
Old 08-12-2004 | 11:58 PM
  #120
JayBee's Avatar
Enjoy,
HW
I AM A COMPLETE IDIOT!! Sorry man but initially, how do you do this? I'm trying to figure this out as I'm typing this.
- jAyBeE
JayBee is offline
