Keyence ESC
Old 04-02-2007 | 02:01 AM
  #736
surrealmaterial's Avatar
well wat do i do? is it fixable?
surrealmaterial is offline
Old 04-02-2007 | 02:35 AM
  #737
sosidge's Avatar
I don't think it's something you could fix yourself. Best bet is to contact your supplier and see what they say.
sosidge is online now
Old 04-02-2007 | 02:39 AM
  #738
ok thanks
Old 04-02-2007 | 06:20 PM
  #739
has anyone else here got any blown leds? are they blown from impact? are they fixable yourself?
Old 04-19-2007 | 08:49 PM
  #740
Hey guys,
seeing as though all my screen leds are out i need someone to tell me exactly what buttons to press and for how long to load the default value "P6".
Thanks,
Much appreciated
Old 04-21-2007 | 09:49 PM
  #741
c'mon anyone? plz
Old 04-22-2007 | 11:17 AM
  #742
cheehtae's Avatar
can't acctually tell since you don't know where your settings at right noe, best thing to do is to contact schumacher and have them replace it for you.
cheehtae is offline
Old 04-22-2007 | 12:09 PM
  #743
Originally Posted by surrealmaterial
Hey guys,
Thanks,
Much appreciated
If its the Rapida Pro here we go
1. Turn on and wait for the motor to blip on (this lets the HELLO message finish).
2. Press the right arrow 6 times.
3. Press the centre (or I find both arrows a better method).
4. Press the right arrow 5 times.
5. Press the centre for 4 seconds slightly longer is better than short).
6. Press the centre.
This should have you loaded program 6.
Good Luck.
Steve B is offline
Old 04-22-2007 | 01:29 PM
  #744
celtic's Avatar
hope someone can help just got rapida pro run 19 turn touring car c2 or check point motors in england any good starting point settings tanks
celtic is offline
Old 04-22-2007 | 02:58 PM
  #745
Good Luck.
thankyou, Much appreciated..
Old 04-22-2007 | 03:58 PM
  #746
I run these settings with a 19 turn CP
nutr - 4p
d_po - 0p
b_po - 10p
nubr - 0p
F_br - Off
EnSA - 70p (with schottky diode)
d_Fr - 2.2 (any lower I find the car to twitchy on power out of corners)
b_Fr - 5.0
nbFr - 5.0 (but dosent matter because its turned off.
Steve B is offline
Old 04-24-2007 | 11:22 PM
  #747
Default 540 Racing
Good Day.
Which ENSA setting is best for 540 , using 100% ensa, or using 0% with a schottky ?
Also is using d_po of 40-50 too much or too little for 540 ?, would it heat the motor more using so much punch ?
MoonTrap is offline
Old 04-25-2007 | 04:23 PM
  #748
edward Haywood's Avatar
Unhappy Keyence ESC
Where can you find these at everyone is always out of stock
edward Haywood is offline
Old 04-25-2007 | 04:31 PM
  #749
Sigearhead's Avatar
You can find the Rapida Pros at www.racing-cars.com
That's the Schumacher website, they distribute them here in the US and usually have them in stock.
Sigearhead is offline
Old 04-26-2007 | 01:27 AM
  #750
sosidge's Avatar
Originally Posted by MoonTrap
Good Day.
I can't really comment on the ENSA but with the d-Po setting it is more to do with feel. A big d_po (minimum drive) setting can make the car a bit too fast for technical sections and you can overpower between corners.
