Keyence ESC
Old 02-03-2004 | 10:34 PM
  #61
Korey Harbke's Avatar
Default Re: Zero V Extreme
Originally posted by tridagger
hi guys,
is it necessary to install a capacitor for modified racing? if so, what are the specs of the capacitor needed?
Andrew Cartwright (Sponsored by Schumacher) runs a keyence in his car. He said he ran a cap on it and it blew up. They say in the instructions to not run a cap or a diode.
-Sushi Boy
Korey Harbke is offline
Old 02-03-2004 | 10:57 PM
  #62
Yes the instruction manual says so but someone told me that he already blew 2 of it without using caps and diodes. Now he has installed a 10000uf cap and a diode and it has no problems so far.
I think I will just go without the caps and diodes. Thanks anyway, just want to get your opinions on this.
tridagger is offline
Old 02-04-2004 | 05:00 AM
  #63
coastaltony's Avatar
Proudwinner,
YGM
coastaltony is offline
Old 02-04-2004 | 10:12 AM
  #64
Ian S's Avatar
Originally posted by John Fontaine
I have one, and somehow in the middle of the race I got hit by another car and it went into SET mode. How is this possible? You have to hold down both arrows for 5 seconds and the impact wasn't nearly that long. The turn marshal had no clue what was wrong so I had to leave the drivers stand and reset the switch so I could continue the race. Wierd...
I've had this happen aswell, the middle button of the 3 only needs to be pushed for a split second to go into set mode and yes it is very annoying!
Ian S is offline
Old 02-04-2004 | 11:03 AM
  #65
jc510's Avatar
Default Does any 1 know?
Can a Keyence A-01 run with only 4 cells?
I tried it and the car glitched to where it couldn't be driven.
jc510 is offline
Old 02-04-2004 | 11:27 AM
  #66
I run 2 of them in my 1/12th scales.
Les
TexRacer is offline
Old 02-04-2004 | 11:58 AM
  #67
jc510's Avatar
I might have a bad cell on my battery pack. I'll try it in my other car.
jc510 is offline
Old 02-05-2004 | 02:40 PM
  #68
coastaltony, check your email.
ZER01 is offline
Old 02-07-2004 | 11:19 PM
  #69
2QCK2C's Avatar
Hello all,
Has anyone encountered being locked out while trying to program
the initial drive and brake high points?
I have 2 extreme v 2002's 1 I just finished programming. The other one I have been having problems with. I get into the set
and the it locks me out (not letting me do the d hp and b hp.
Any suggestions would be helpful
2QCK2C is offline
Old 02-10-2004 | 08:49 PM
  #70
2QCK2C's Avatar
I figured it out. It programmed fine about 2 hours after.
2QCK2C is offline
Old 02-10-2004 | 09:35 PM
  #71
proudwinner
Did you get a chance to scan that set-up sheet?
[email protected]
Old 02-10-2004 | 10:44 PM
  #72
coastaltony, working on it, you should have it before too long.
ZER01 is offline
Old 07-25-2004 | 08:25 PM
  #73
miniracer's Avatar
Default how to reset keyenece zero extreme
anyone know how to reset the zero extreme back to factory defaluts for all settings? there is no mention of how to reset it in the manual. my keyence has quite a few busted led's so can only program it to work with my transmitter barely.
miniracer is offline
Old 07-26-2004 | 07:05 AM
  #74
STLNLST's Avatar
Default Re: how to reset keyenece zero extreme
are you running stock or mod? If you are running stock then load profile P5. If you run mod then load P6. These default settings should be pretty good if you use them for those two classes. Good luck!!!
STLNLST is offline
Old 07-26-2004 | 11:21 AM
  #75
Tim Stamper's Avatar
I've browsed most of the posts and was unable to find some info that I need. I just purchased a zero extreme used from someone and I would like some help in settings for various motors. I run tc 19t and 12th stock and mod. I found a 12th mod setup for the esc. Does anyone have a 12th stock and a 19t TC setup to use. Currently I have it set to what the quick reference guide says for 23t motors for the 19t TC. Any help would be appreciated.
Thanks,
Tim Stamper
Tim Stamper is offline
