Hobbywing ESC's
#616
I thought there was a setting in the LCD Box for automatic detect of 2 cell or 4 cell. There is also (as I read) a setting for other choices. Sounds like it might be set wrong.
#617
a fully charged 2s is at 4.2 per cell which reads as a low voltage 3s
i have manually changed it to 2s using the lcd and still no luck
thinking about slapping in a 4s then trying to change it manually from 4s to 2s again... heard that worked for someone
my last resort will be to put my CC BEC on. i REALLY dont want to do this
#618
auto cell detection doesnt work on these
I have run my Ve8 with 2 cells with the 2250 Kv buggy motor and it seems to work fine. But your glitching issues definitely sounds like a BEC problem. Have you tried a capacitor on your receiver?
#619
The only problem I was having running my 150A on 2s was with the servo I have drawing so much that I was getting brownouts to my transponder. After installing the CC BEC all is well now. And running the CC 3800 4 pole I swear it is just as smooth as any sensored combo I have. I have nothing but good things to say about the speedo.
#620
Car setup
Auto detect should work just fine when using 2s or 4s packs on the 80A Xerun. It does for me anyway. A 3s pack would have to be discharged down to 2.8V/cell resting to be recognized as a 2 cell, which would damage the cells.
What gears and esc setup?
Thaks.
#621
Xerun 1S Vs 120A (2S)
gurus!!!
have a question about the 120A V2.1(2S) vs the 1S version? aside from the BEC what is the advantage of using a 1S as against the 120A 2.1 xerun ESC with FAN?
Is the 1S requires a Fan?( i think Fan is included right? or is ok with out it? dont have plans on using more thatn 2S lipo onto it and the lowest Turn i can run is 6.5T but realistically 8.5T will be enough..
any feedback would be appreciated, as im planning to get one for my sons Truck.
thanks,
thanks,
#622
Another "what have i got"-question
Well, i know what it says on this esc, atleast enough to open the right thread to ask in
All i need is a manual for this one, i don't exactly know if i have been looking at the right one after a bit of searching.
Oh, and can this be used together with a programming card? Or do i just use the little red button by the on/off-switch?
#623
it cant use a program box like the blue version but can be programmed by the little red button.
fairly sure this is the manual http://www.hobbywing.com/uploadfiles...l/HW-09-80.pdf
i had one worked well
#624
gurus!!!
thanks,
thanks,
but it will also run 2s with stock (dynamic timing) or mod firmware
fairly sure i doesn't use a fan or need one
#625
Kinda a known thing for hobby wing/ speed passion, use the programming box and set your reverse to 100%, than under your driver profile choose Forward/Brake after that you will have all the brake you need.
For some reason the ESC needs reverse set at 100% to have strong brakes even if you are not using reverse.
#628
fairly sure the black case 80a was made for a specific company (think a rtr 1/8)
Thanks a bunch! I will have a better look at it tomorrow.
#629
The black ones are sold in Redcat, exceed and serveral others budget RTR models. They are exactly the same specs as the blue 80A cased ESC. But a hole under the sensor post plug. Ran one with a Castle 1515 2200kv for along time in my Revo and Maxx. As water resistant as you'll ever need and as much power as higher priced ESC's
And VERY smooth paired with a quality motor.
Just got a killer deal on a nice 8ight e 2.0 and just placed an order for the 80A/2250kv M1 combo. Should be great!
#630
Thanks for the little review and enlightning, nice to hear I have noticed this hole/slot you mention above, should i leave it as it is or should i have covered it?
