Hobbywing ESC's
Old 09-06-2011 | 08:56 AM
  #526
Originally Posted by coaltrain
I'm running a Hobbico CS-170, same as older hitec 5955, similar to 7955. I'm wondering if I can try something to give me an idea if this is my problem. Can I use a 6.0v nitro receiver pack to see if that solves my glitching problem? I think I can wire it like an external bec, remove red wire from esc and then just plug the battery into the receiver. If that works then that should tell me if adding a bec would fix my problem right?
sorry, i am not familiar with nitro stuff.. try to find someone with bec you can borrow..
bustanut666 is offline
Old 09-06-2011 | 10:03 AM
  #527
Originally Posted by RC*PHREAK
truggy? what truggy are you running?
I am running a Hobao Hyper TT.
V1RUS is offline
Old 09-06-2011 | 10:15 AM
  #528
yes that will test it, infact alot of guys do that with the MMP up here. Did a cap help ?
Manatarms25 is offline
Old 09-06-2011 | 11:54 AM
  #529
What is the difference between version 2.0 and 2.1? Is it worth upgrading?
Old 09-06-2011 | 11:57 AM
  #530
aloksatoor's Avatar
get v3 totally worth it.
aloksatoor is offline
Old 09-06-2011 | 12:08 PM
  #531
I read somewhere that upgrading esc to turbo version is only for stock motors. I am running offroad 550 motors and 4 pole motors. Is there advantage for v3 for these motors?
Old 09-06-2011 | 01:41 PM
  #532
aloksatoor's Avatar
No I got it for my 10.5 motor. It screams with the turbo and even if you disable turbo the timing adjustments are more from the older version.
Old 09-06-2011 | 01:46 PM
  #533
i guess i'll just leave mine on older version since i don't even use a sensored motor now...so no timing needed.. and even with my old tekin 4.5 sensored, i barely ran timing, gets too hot..
Old 09-06-2011 | 06:25 PM
  #534
coaltrain's Avatar
Powered the servo and RX with a 5/cell nimh pack and it seems to work fine. Like I said earlier Im new to electric. Will a bec do the same thing as the RX pack did with less weight?
coaltrain is offline
Old 09-06-2011 | 06:31 PM
  #535
Can you even buy the v3 yet ?
Old 09-06-2011 | 06:32 PM
  #536
Yes sounds like a bec will fix your problem, I cant believe that some of these have a weak bec. Mine worked great with a 7995 ?.
Old 09-06-2011 | 06:51 PM
  #537
lip
Guys, does rcecho sell legit hobbywing?
http://www.rcecho.com/xerun-4000kv-s...-lcd-card.html
lip is offline
Old 09-06-2011 | 08:02 PM
  #538
larlev's Avatar
One thing also...if your radio allows for travel/endpoint adjustment make sure and set it so servo is NOT pushing 100% right or left. Back it off 4 positions or so. this will help with current draw.
What receiver are you using?
A cap is just a battery so to speak. It keeps the receiver voltage from dropping below a certain point that causes the glitching/brownouts.
MMP and spektrum are the worst. I know guys running KO propo and MMP and have zero issues. Savox servos are also bad with spektrum. I understand this is a HW thing, but applies nonetheless.
larlev is offline
Old 09-06-2011 | 11:02 PM
  #539
murky123's Avatar
Default 120A v2.1 xerun For The Win !
I have this xerun 120A v2.1 with the latest stock software in my 2wd losi 22 1/10 buggy. I run it on 2s lipo with a speedpassion 10.5 turns ultra sportsman.
my buddy has a durango 4wd 1/10 buggy with a castle mamba max pro and a 6.5 turns motor.
on the straight away our topspeed is exactly the same, I can keep up with his 4wd buggy .
this is done on a hardpacked clay outdoor offroad track.
I just love this speedo.
murky123 is offline
Old 09-06-2011 | 11:28 PM
  #540
I am having problems with program cards. When I plug it in, card turns on for split second and then off. Tried 2 different cards and both are doing this. So I thought it was lose wire, changed that out, put new plugs and still doing same thing. Everything works fine but cannot change settings on esc. Anyone have this issue. I have the 120a xerun. Do u think it's a bad bec that can cause this?
