soldering tip
Old 12-03-2007 | 10:19 AM
Default soldering tip
I just bought a hakko 936 solder station and I was wondering what kinda tip is best for rc? I know a chizzle tip but what size?
C_Money is offline
Old 12-03-2007 | 10:40 AM
I USE THE 2.4MM CHISEL FOR MOST RC APPLICATIONS AND 1MM CHISEL FOR FINE WORK SUCH AS SERVOS
FITO is offline
Old 12-03-2007 | 07:44 PM
Joel Lagace's Avatar
love the hakko
I use a 4.5mm for every day soldering: Battery bars, motor tabs,brushes, hard wiring to battery bar ends and motor tabs....
Joel Lagace is offline
Old 12-04-2007 | 05:23 AM
BSchorr's Avatar
R/C Tech Elite Member
Ya, using the small 1-2mm tips for soldering the wires on a servo for when shortening or making servo wire longer.
5.2mm for your batter building, soldering wire to your packs, etc..
Since I cant post ebay auctions, look for the seller, "niosales"
Replacement Tips
Part No: 900M-T-0.2RB
TIP,0.2RB,900M/907/913
Part No: 900M-T-0.5C
TIP,0.5C,900M/907/913
Part No: 900M-T-0.8C
TIP,0.8C,900M/907/913
Part No: 900M-T-0.8D
TIP,0.8D,900M/907/913
Part No: 900M-T-1.2D
TIP,1.2D,900M/907/913
Part No: 900M-T-1.2LD
TIP,1.2LD,900M/907/913
Part No: 900M-T-1.5CF
TIP,1.5CF,900M/907/913
Part No: 900M-T-1.6D
TIP,1.6D,900M/907/913
Part No: 900M-T-1.8H
TIP,1.8H,900M/907/913
Part No: 900M-T-1C
TIP,1C,900M/907/913
Part No: 900M-T-1CF
TIP,1CF,900M/907/913,SPECIAL
Part No: 900M-T-2.4D
TIP,2.4D,900M/907/913
Part No: 900M-T-2C
TIP,2C,900M/907/913
Part No: 900M-T-2CF
TIP,2CF,900M/907/913,SPECIAL
Part No: 900M-T-2LD
TIP,2LD,900M/907/913
Part No: 900M-T-3.2D
TIP,3.2D,900M/907/913
Part No: 900M-T-3.2LD
TIP,3.2LD,900M/907/913
Part No: 900M-T-3C
TIP,3C,900M/907/913
Part No: 900M-T-3CF
TIP,3CF,900M/907/913,SPECIAL
Part No: 900M-T-3CM
TIP,3CM,900M/907/913
Part No: 900M-T-4C
TIP,4C,900M/907/913
Part No: 900M-T-4CF
TIP,4CF,900M/907/913,SPECIAL
Part No: 900M-T-B
TIP,B,900M/907/913
Part No: 900M-T-H
TIP,H,900M/907/913
Part No: 900M-T-I
TIP,I,900M/907/913
Part No: 900M-T-K
TIP,K,900M/907/913
Part No: 900M-T-LB
TIP,LB,900M/907/913
Part No: 900M-T-R
TIP,R,900M/907/913
Part No: 900M-T-RT
TIP,RT,900M/907/913
Part No: 900M-T-S3
TIP,13/64in. D,900M/907/913
Part No: 900M-T-S4
TIP,SMD,MICRO,900M/907/913
Part No: 900M-T-S6
TIP,C1.27,MICRO,900M/907/913
Part No: 900M-T-S7
TIP,C1.18,MICRO,900M/907/913
Part No: 900M-T-S8
TIP,LC,900M/907/913
Part No: 900M-T-S9
TIP,3/64in. D,900M/907/913,900M-T-S1
Part No: 900M-T-SB
TIP,SB,900M/907/913
Part No: 900M-T-SI
TIP,SI,900M
BSchorr is offline
Old 12-04-2007 | 06:53 PM
ok well I will give the 4.5 and 5.2 a try first, I want to make sure and get a big enough one so it keeps heat in. Also do you have to use flux on everything? I watched videos and it looks like people dont use flux a lot of the time.
C_Money is offline
Old 12-04-2007 | 09:26 PM
BSchorr's Avatar
Always clean the tip on the sponge before using it, tin it before putting it away. I would shut it off if you use bullet connectors on your packs though. and if u dont plan on taking ur motor out..
BSchorr is offline
Old 12-04-2007 | 09:41 PM
so what about useing flux on the the parts you soldeer though? I didnt see people useing that
C_Money is offline
Old 12-05-2007 | 03:30 PM
Swanny's Avatar
Modern day solders have flux built in to them, hence why you don't see many people using it separately.
Swanny is offline
Old 12-05-2007 | 06:15 PM
ok cool thanks guys
C_Money is offline
