Futaba 3pk question
I'm aquiring a 3pk with the spektrum module and receiver and would like to know if I can use digital servos with this setup?
Also how muchg better is the Futaba Fasst system over the spectrum and can I use digital servos with that setup as well?
Thanks in advance.
James
Thanks in advance.
James
Yes, you can use digital servos with the Spektrum systems. In fact it is better to use digital servos. The Futaba FAAST 2.4GHz is a little faster then the Spektrum. The price of the Futaba receivers are a little more then the Spektrum. The Spektrum receivers are smaller then the Futaba receivers especially the micro Spektrum receivers. You can use digital servos with any 2.4GHz systems.
Take Care,
Cheers, Patrick
Take Care,
Cheers, Patrick
Thanks guys,
I'll be putting them in my RC boats and 1/4 scale sprint cars I've always used the 3PJ PCM radios and decided to upgrade. The radio I'm getting already has the Spektrum system with it but I was just curious if it would had been a good move to get the Fasst and sell the spektrum? Thats why I asked which one was more dependable.
James
James
I also have a question about this radio...
How does the "Lap Counting/Timer" system work? Is the transponder info sent directly to radio after the car crosses the start/finish line? I think this is a great feature, but I haven't actually used it yet and I am curious as to how it all works.
Thanks guys
Thanks guys
Hi,
As far as I know, the lap counting/timer is just like a stop watch except that it is built into the 3pk radio. I don't think the radio can receiver data from the transponder. I use it to set a time to alert me when to come in for a fuel stop (3pk radio beeps but I think 3pks also vibrates).
It will be great if the lap times & lap data can be sent to the radio. One day I hope...
Regards,
Joe Ling
Thanks guys
Thanks guys
Regards,
Joe Ling
I like your idea about using it for fuel stops...I will definitely start doing that:-)
