Need help programming my Hobbywing EZRUN Max10 ESC >
Like Tree1Likes
Old 04-23-2026 | 02:19 PM
Default Need help programming my Hobbywing EZRUN Max10 ESC
So I am trying to get an old RC buggy running again. I have to use an NIMH battery because my battery tray won't hold a LIPO battery. My ESC is an Hobbywing EZRUN Max10 and I have the program card for it. I also have a Hobbywing motor in it as well. So with my NIMH battery when I turn on the ESC it blinks red and it a gives throttle for about 5 seconds and then the ESC shuts off. What settings do I need to change on my ESC with my program card for the NIMH battery to work? Thanks for your time guys!
Clodfan is offline
Old 04-24-2026 | 01:04 AM
Roelof's Avatar
You need to change te low voltage cut off
Roelof is offline
Old 04-25-2026 | 07:33 AM
What setting do I change the low voltage cutoff too?
Clodfan is offline
Old 04-25-2026 | 09:15 AM
Roelof's Avatar
Just switch it off
Roelof is offline
Old 04-25-2026 | 11:03 AM
Crap now my program card is just doing 3 lines its not giving me numbers... What do I do?
Clodfan is offline
Old 04-25-2026 | 01:17 PM
Roelof's Avatar
Did you connect it to the special programming port or did you use the cable that is connected to the receiver?
Here the manual: HW-SMA527DUL-V2_XERUN XR10-Justock G3(Handout Spec)_220407
Roelof is offline
Old 04-25-2026 | 05:32 PM
gigaplex's Avatar
That's the wrong ESC
gigaplex is offline
Old 04-26-2026 | 02:45 AM
Roelof's Avatar
The naming of the ink is not of the file behind it, that is a MAX10. I still think it is the issue, using the wrong port to connect to the programmer. Otherwise you can program it w/o a card/box
Roelof is offline
Old 04-26-2026 | 05:33 AM
gigaplex's Avatar
It's a Max10 G2 which is quite a bit different.
gigaplex is offline
Old 04-26-2026 | 07:05 AM
Mac The Knife's Avatar
R/C Tech Elite Member
Based on the information given by the OP, I came up with the same manual as Roelof. If it's wrong, be helpful and post a link to the correct one.
And the manual says to turn off LVC if you're running NiMH cells.
Mac The Knife is offline
Old 04-26-2026 | 08:35 AM
It is just a MAX 10 not a G2. I have it hooked up to the ESC and to the program card it just gives me 3 lines.
Clodfan is offline
Old 04-26-2026 | 09:21 AM
Looking through their list of manuals, there is this one,,,, https://support.hobbywingdirect.com/...20207098354579 and you may be able to disable the LVC without using a program card by just using the set button at the esc.
gigaplex likes this.
Old 04-26-2026 | 10:49 AM
Roelof's Avatar
As the manual state:
the programming port of this ESC is also the fan port, so you need to unplug the fan first and then plug (one end of) the programming cable in the PRG/FAN port and the other end (of the programming cable) in the ESC port on the LCD program box. Please don’t use the throttle control cable (also called Rx cable) on the ESC to connect the program card/box, otherwise the program card/box won’t function.
​​​​​​​If that did not work then just use the pushbutton to go through the menu.
Roelof is offline
Old 04-30-2026 | 11:23 AM
So when I plug in my battery and power on the ESC it turns green for a second and then it stays flashing red. There is no throttle. but the front wheels will turn back and forth. My program card isn't working. How do I fix this? Thanks for your time guys!
Clodfan is offline
Old 04-30-2026 | 01:57 PM
Have you calibrated the ESC to your radio?
glennhl is offline
