Like Tree8Likes
  • 2 Post By HOTROD716
  • 5 Post By billdelong
  • 1 Post By Roelof
power supply?
Old 02-14-2025 | 03:16 AM
strodedawg's Avatar
Default power supply?
Hello,
looking for a good power supply for my charger as my old one finally gave out. what are some of the choices people are using at the track
strodedawg is offline
Old 02-14-2025 | 04:56 AM
petersen114's Avatar
Originally Posted by strodedawg
Hello,
I use the Motive Power Brick.It’s only 60 amps so might not meet your charging requirements.The Fantom units are good and are at 75 amps.
petersen114 is offline
Old 02-14-2025 | 06:18 AM
HOTROD716's Avatar
Find a used HP server supply on eBay ($20ish). Need to solder in a resistor, some connectors and you are good to go.
Bud and staiguy like this.
HOTROD716 is offline
Old 02-16-2025 | 04:48 PM
I have instructions here on how to convert an HP supply which is fairly easy to do in minutes with basic soldering skills:
https://www.rcgroups.com/forums/show...0#post43199655
billdelong is offline
Old 02-18-2025 | 11:24 AM
rustyus's Avatar
Hello,
The questions I have are:
What charger is being used?
What are your charging practices (what charge rates/how fast do you charge)?
What are your largest LiPo packs (cell count/capacity)?
I was sort of in same situation, but I needed a 24V power supply to get better use out of a charger's potential power. A charger needing input of ≥24V to get its maximum power... you may run into underwhelming performance with a 12V power supply.
rustyus is offline
Old 02-18-2025 | 12:33 PM
strodedawg's Avatar
A toolkit rc m8d. Indoors 10a max 2s. Outdoor 5th 2x6s 7600 mah packs @ 8A
Old 02-18-2025 | 01:42 PM
According to the manual, the charger is rated for 10V min -49V max input and doesn't specify any variance for power output depending on voltage input:
https://images.amainhobbies.com/imag...ger_Manual.pdf
That said I would go with a 12V supply to keep costs and space/weight to a minimum
Old 02-19-2025 | 12:55 AM
Roelof's Avatar
I also did read the manual and you did forget a very important specification.
The input current is limited to 60A, with a 12v PSU you are limited to a 700w charge but that is still within the mentioned needs.
gigaplex likes this.
Roelof is offline
Old 02-19-2025 | 07:59 AM
HOTROD716's Avatar
I was able to find (2) used Mean Well RSP-1000-24 for $65/set. Not the easiest to carry, but has the power when you need it.
Old 02-19-2025 | 09:05 AM
much appreciated for including that important spec!
using watts law
W = V x A
700W - 10% charger inefficiency = 630W usable load
6S = 6 x 4.2V = 25.2V
630W / 25.2V = 25A
So you can charge 1 pack at 25A max or 2 packs at 12.5A each port without stressing a 12V PS where the supply I linked above is rated for 750W.
Old 02-19-2025 | 09:18 AM
Bud
We did this for a slot car drag strip a few years ago. Worked like a champ.
Bud is offline
Old 04-13-2025 | 09:46 AM
strodedawg's Avatar
Thank you all for the great info. But now that I have a power supply for indoor, New outdoor track has no power and was looking into a lifepo4 battery as a power bank. What are the opinions on a 250 ah lifepo4 to charge two 7600 6s or two 9000 2s for a race day. Never both classes on the same day
Old 04-13-2025 | 06:20 PM
trilerian's Avatar
For outdoor with no power, I use a 100Ah LiFePO4. Myself and another racer share the same battery, running mod TC. We get a lot out of it, lol. At least 10 cycles a piece plus running tire warmers and other accessories. I did the math last year and figured we would need approximately 50Ah, which is about right. Generally I have to put in about 40% back into the battery when charging it.
trilerian is offline
Old 04-13-2025 | 06:28 PM
strodedawg's Avatar
So 250 might be overkill
Old 04-14-2025 | 10:05 AM
trilerian's Avatar
That is going to depend. How many times do you need to charge the 6S batteries? How many mAh do you generally put back into them?
250Ah LiFePO4 - 12.8V - 3200W
7600mAh 6S - 25.2V - 191.52W <-- Full charge, not likely using all the capacity, so figure maybe 50%? Let's error on the side of caution and say 100W per charge.
Not dropping below 20% charge on the LiFePO4 gives you approximately 25 charges.
With a 100A battery you would get about 10.
There will most likely be some inefficiency needed to be accounted for, plus whatever else you want to power. I would feel comfortable saying you can get 8 charges of 50% or less and power whatever else you need (small things) with a 100Ah battery.
You need to do the math, add some overhead and try to stay above 20% charge on the LiFePO4.
