Motor rotor replacement >
Like Tree7Likes
Old 02-11-2025 | 07:18 AM
  #16
Zerodefect's Avatar
Cook the stator.
I'm only worried about the rotor losing strength.
It's extremely hard to roast the stator open or shorted. In which case, buy a new motor.
OffRoadJunkie likes this.
Zerodefect is offline
Old 02-11-2025 | 09:00 AM
  #17
OffRoadJunkie's Avatar
Originally Posted by gigaplex
Depends on the enamel type used. Hobbywing recently changed to a high temperature enamel that can do 220C, but there are types that fail around 105C (220F). I'm not sure what the typical rating is for most motors on the market right now.
If the stator wire is going black, that's the enamel discolouring, not the copper. Copper can handle way higher temperatures. The rating is generally what the insulation can handle.
As for the motor reaching 250F, don't forget that the motor isn't at a uniform temperature. The windings can be hotter than the can or the temperature sensor on the sensor board.
I'm not a motor engineer. I just like to run their numbers.
So, let me ask this question. The purpose of the enamel is to protect the winding from shorting out on each other. So, discoloration, of the enamel, should not affect the resistance and/or performance of the motor. Only deterioration, of the enamel, will affect the performance, but at that point, the moto will be shorted and not work. Is this accurate?
OffRoadJunkie is offline
Old 02-11-2025 | 08:38 PM
  #18
gigaplex's Avatar
The enamel protects against shorts and also protects the copper from oxidation. Once the enamel is compromised, it might not create a short but it can lead to corrosion of the copper.
gigaplex is offline
Old 02-12-2025 | 12:56 AM
  #19
Roelof's Avatar
Corrosion of copper is just at the surface, it will take a lot of time (many years) it actually is deeper to the core.
Roelof is offline
Old 02-12-2025 | 07:12 AM
  #20
I no longer race 1/10 stock classes anymore, but the Texas summers are brutal on stock electronics. I had to gear up to be competitive and had 2 fans on my motor to help give it a fighting chance, but I generally saw performance fade between 6 months to a year of racing. Yeah I could probably run my overworked electronics for many years on end, but it would put me at a disadvantage running aged out electronics. I pay a lot of money to play with toy cars so I want to make sure I have the best advantage possible when I race
billdelong is offline
Old 02-12-2025 | 08:34 AM
  #21
Roelof's Avatar
And that is why the ETS and many EU countries use the concept of a minimum FDR determined per track. And it can be measured.
Roelof is offline
Old 02-12-2025 | 09:33 AM
  #22
I know we are all aware that heat will weaken the strength of rotor. When the rotor cools off, the magnetic strength comes back, but not all of it.
Old 02-12-2025 | 11:51 AM
  #23
staiguy's Avatar
At that point you might as well get a mini wine fridge and put your cars in there to cool off. I don’t think those motors ever cooled off in Texas heat
staiguy is offline
Old 02-12-2025 | 12:40 PM
  #24
gigaplex's Avatar
How hot are we talking in Texas? Melbourne where I race gets pretty toasty too, high 30's and occasionally low 40's (or high 90's, low 100's in freedom units) and we make do.
gigaplex is offline
Old 02-12-2025 | 12:58 PM
  #25
Texas can reach over 110*F. However, as a Texan will tell you, it's a humid heat. Up here, in northern Cali, it will reach over 110 with a dry heat.
staiguy likes this.
