Originally Posted by XCELL
(Post 16135732)
Thinking of purchasing this charger, has a lot of great features and seems that those who have it really like it. I wonder if you could use the RC Discharger system with this charger for the recycle discharge function? May not be possible, but just a thought.
Patrick |
The RC Discharger system is designed to be use with ichargers, it allows you to use the regenerative discharge function to discharge into a battery. It is an expensive unit, however I do not think it will work with this charger.
Patrick |
(Post 16135768)
Patrick |
(Post 16135768)
Patrick |
RC discharger is actually doing nothing fancy. He just creates what is mentioned in the manual and with his 3D printer he creates a nice housing on it.
Regenerative Discharger 2S - RC Discharger Nothing more than a case with a battery and a power supply. And so far I can see he probably did add a BMS for the battery. |
Hi guys, reading your reviews, I ordered one too, can anyone tell me if by updating the firmware there is a risk of losing the precision of the balancer calibration? or are there no problems?
Originally Posted by Roelof
(Post 16135891)
Originally Posted by disaster999
(Post 16135936)
Im sure theres more than "just a BMS for the battery". There must be some logic and voltage and current detection and power switching from battery and AC power. It needs to keep the battery at a low charge all the time in order for it to be ready to accept charge back from the charger and be intelligent enough to switch to AC power when the battery voltage drops too low.
Originally Posted by sav13
(Post 16135896)
Ciao ragazzi, leggendo le vostre recensioni, ne ho ordinato uno anche io, qualcuno mi sa dire se aggiornando il firmware si rischia di perdere la precisione della taratura del bilanciatore? oppure non ci sono problemi?
(Post 16135936)
Just got a M8d today. I was wondering if you guys have changed the "balance start voltage" in the settings. It was taking forever for the charge to end with the default setting.
Originally Posted by dway100
(Post 16136655)
Originally Posted by biz77
(Post 16136774)
That is the biggest complaint I have with the charger right now. Yes, we did update one charger to the 400mV setting, which I believe was as high as it goes for balance start voltage. I did not yet hear back if this helped speed up the final stage of charging however.
(Post 16136780)
After I posted last night, I lowered it to 10mv and it made a huge difference. It charged at my set amps until a cell hit 4.19 then it slowed down and balanced from there.
(Post 16136780)
Dopo aver pubblicato ieri sera, l'ho abbassato a 10 mV e ha fatto un'enorme differenza. Si è caricato ai miei ampere impostati finché una cella non ha raggiunto 4,19, poi ha rallentato e si è bilanciato da lì.
| All times are GMT -7. It is currently 05:34 PM. |
