ToolkitRC M8D Charger >
Like Tree131Likes
Old 09-05-2024 | 07:38 PM
  #16
STLNLST's Avatar
Charger is pretty darn nice. Touch screen isn’t perfect but neither is the Muchmore. Bench test impressed. Will have to wait to run my race packs on race day. Good job Toolkit.
STLNLST is offline
Old 09-07-2024 | 03:45 PM
  #17
running a 6 cell 5000 mah battery set your input to battery and your discharge to recycle then you can discharge up to 30 amps
STLNLST likes this.
jmanikis is offline
Old 09-07-2024 | 07:03 PM
  #18
teeforb's Avatar
I’m confused with the normal and recycle discharge. Normal is 40w and recycle is 800w. What’s the difference?
teeforb is offline
Old 09-08-2024 | 10:02 AM
  #19
Normal uses the internal resistance built into the charger. Recycle is discharging from a battery on the output side of the charger to a source battery on the input side. This source battery powers the charger in place of a power supply.
biz77 is offline
Old 09-12-2024 | 05:57 AM
  #20
function>form's Avatar
what leads is everyone using with this charger?
trickedyfz450 likes this.
function>form is offline
Old 09-12-2024 | 06:21 AM
  #21
Roelof's Avatar
The ones that fits the charger on one side and the battery on the other side?
As if charging leads will make a difference....
Roelof is offline
Old 09-12-2024 | 04:21 PM
  #22
I didn’t say “which leads will make my battery have more power or my rc car faster” but thanks for the worthless info, clown.
Old 09-12-2024 | 04:22 PM
  #23
for the non sarcastic, worthless posters- does anyone have leads that they like to use on this charger as far as brand/quality/part numbers? Thanks
Old 09-12-2024 | 11:28 PM
  #24
Roelof's Avatar
Then why not visit some shops and look if they have something you want?
Roelof is offline
Old 09-13-2024 | 02:43 AM
  #25
petersen114's Avatar
lol.
petersen114 is offline
Old 09-13-2024 | 04:12 AM
  #26
dude, stfu.
Old 09-13-2024 | 07:09 AM
  #27
Roelof's Avatar
dude, stfu.
Why do people always get rude if they are not that smart enough to look up such very easy to find info by them self?
You can find these cables in any RC shop, then why the question?
hunterdawg likes this.
Roelof is offline
Old 09-13-2024 | 07:31 AM
  #28
gigaplex's Avatar
Charging leads can make a difference. They can affect IR readings and can cause the charger to go into CV mode early. Usually more of an issue with charge leads that connect the balance lead to the wrong end of the power lead in order to save money on the balance wire.
gigaplex is offline
Old 09-13-2024 | 08:31 AM
  #29
WYLDTHING's Avatar
Super Moderator
Here's an idea....if you don't have something positive and constructive to contribute to the conversation, then don't say anything at all. Anymore insults/unnecessary comments will result in some time off from the site. Thanks.
WYLDTHING is offline
Old 09-13-2024 | 09:30 AM
  #30
The TQ wire strain relief charge leads are nice. They protect the area that always seems to breakdown. In the past my charge leads always seems to fail at the charge lead to battery interface. Eventually the balance wire solder or the balance wire always seem to degrade after so many plug and remove cycles.
https://www.michaelsrchobbies.com/tq...n-reliefs.html
Roelof can be blunt and a little condescending at times but his suggestions are usually sound.
malkiy is offline
