Remove set screw in pinion >
Like Tree7Likes
  • 2 Post By glennhl
  • 1 Post By OffRoadJunkie
  • 1 Post By billdelong
  • 1 Post By DirkW
  • 1 Post By Geezatec
  • 1 Post By Sabin
Old 05-15-2024 | 03:09 PM
Default Remove set screw in pinion
Hello all, the set screw was broken and left the top part inside the pinion. Any idea how to take it out? Thanks
Smashrc is offline
Old 05-15-2024 | 03:19 PM
Left handed drill bit. Should spin it right out. Only trouble is if you don't have a left handed drill bit set or know someone who does, it will cost you more to buy the drill bit than it would cost to buy a new pinion.
gigaplex and OffRoadJunkie like this.
glennhl is offline
Old 05-15-2024 | 03:40 PM
EZ out ,like glennhl said left handed drill bit .EZ out has drill bit on one side and the extractor bit on the other side ,.Works like a charm
martind1318 is offline
Old 05-15-2024 | 06:07 PM
OffRoadJunkie's Avatar
I agree with the left-hand bit, but it would be cheaper to just buy another pinion. Chances are, you will break the bit because it is so small. OR, you will damage the threads because you got a bit that is too big and/or it does not go in the center.
disaster999 likes this.
OffRoadJunkie is offline
Old 05-15-2024 | 09:30 PM
TankBond
I use a little dab on the tip of screwdriver, it helps with stripped screws and preventing stripped screws.
I bought mine at Wal-Mart, but here is an Amazon link.
https://www.amazon.com/DAP-00177-Tan...s%2C159&sr=8-2
Ricochet Rabbit is offline
Old 05-16-2024 | 07:53 AM
Lesson learned here is invest in a micro-torch and apply heat for about 5 seconds to melt the thread lock, then remove the screw... you will never break/strip a screw ever again with this method
hunterdawg likes this.
billdelong is offline
Old 05-16-2024 | 09:56 AM
Geezatec's Avatar
EZ out, Screw Extractor, Left hand drill sound like a good ideas. Only thing you purchase them in sets. Break them you mite as well purchase new pinion. I never found one that small. Brain storming! Drill grub (allen) through, smaller then 3mm, Use 2mm Allan and JB Welled into Grub screw to allan. 12- 14 hours later when dried. Use a heat gun to heat up pinion. gently unscrew allan. Good Luck!! JB Welding the allan key, Dremel off the allan screw, allan is good as new. We live and learn!! I learn not to to use loctite om my pinions.
Geezatec is offline
Old 05-16-2024 | 10:11 AM
No reason to.
Andy Koback is offline
Old 05-16-2024 | 10:26 AM
DirkW's Avatar
Pinions are one of the few places (metal in metal) I never use loctite on.
Andy Koback likes this.
DirkW is offline
Old 05-16-2024 | 11:20 PM
Geezatec's Avatar
Dont get me wrong!! There are times we use loctite, any metal to metal contact. Not on composite to composite parts. Use the Blue Loctite and heat up with soldering iron or heat gun.
rustyus likes this.
Geezatec is offline
Old 05-20-2024 | 09:18 AM
I haven't used Loctite on a pinion is decades. However, when I did, I used the purple one. It doesn't hold as tight as the blue.
Old 05-20-2024 | 12:49 PM
I've had grubscrews back out on my pinions during a race, so I started using purple threadlock. It's just strong enough to prevent them backing out and weak enough to let go when I need to remove the pinion.
The purple magic is so good, I use it on everything that I know I won't have to undo frequently - like bulkheads and motor mounts.
OffRoadJunkie likes this.
Sabin is offline
Old 05-20-2024 | 04:06 PM
gigaplex's Avatar
I use blue but very sparingly. Never had an issue with it getting stuck.
gigaplex is offline
