ESC cable and connector sizing >
Like Tree3Likes
  • 1 Post By DirkW
  • 1 Post By Roelof
  • 1 Post By gigaplex
Old 03-18-2024 | 11:38 AM
Questions?? ESC cable and connector sizing
Hello Guys,
I bought a SURPASS HOBBY KK 80A esc and I wondered the cable size only 14AWG what cannot handle 80 amps and the connector xt60, what can handle only 60 amps. I have a 75A brushless motor, and I am worrying because of this. I know that the 75A is a peak value, not continous, but IT would not be more appropriate 8AWG and XT90 plug for this sizing?
Asimov is offline
Old 03-18-2024 | 12:01 PM
DirkW's Avatar
Don't worry.
gigaplex likes this.
DirkW is offline
Old 03-18-2024 | 01:39 PM
gigaplex's Avatar
8awg for an 80A ESC? 🤣
gigaplex is offline
Old 03-18-2024 | 08:39 PM
Geezatec's Avatar
12ga Silicone wire Red and Blk, or all black, is good enough. good enough to solder XT90 ocnnectors.
Geezatec is offline
Old 03-18-2024 | 10:40 PM
gigaplex's Avatar
The stock wires the ESC came with are good enough. If the motor pulls enough current to overload those wires, the ESC will fry first.
gigaplex is offline
Old 03-19-2024 | 10:32 AM
Thank you for all answer.
I am a little bit confused because I read on several site that 14 AWG rated only 15 amps.
Do I misunderstand something?
Asimov is offline
Old 03-19-2024 | 10:41 AM
Roelof's Avatar
14AWG can handle more, it is about the length and the acceptable voltage losses. If you place the ESC next to the motor you only need 10cm of wire. The resistance of 14AWG is that low that with such currents no heat is produced. If you have 50 meter and put 15A through it then there is a chance the wire will get warm.
Roelof is offline
Old 03-19-2024 | 02:21 PM
gigaplex's Avatar
The 15A rating is for building wiring. Wire runs are significantly longer and thermal safety requirements are much more stringent in those regulations than they are for RC.
RetroThutmose likes this.
gigaplex is offline
