Field charging
#46
ya there is a very strong point to havin a field station. so i can charge in the field and not in my house. why would i charge lipos in my house when i can charge them in the field! much safer. It eliminates the risk of catastrophe. I have neighbors around too unfortunately.
#47
Because you'll be charging them in a fireproof battery box. Which you should be doing no matter where you are.
#48
FFS, why come on a forum and ask for advice if all you're going to do is ignore the advice?
Since you're so dead set on overcomplicating this, just buy one of these. It'll power your setup in a field...
https://www.northerntool.com/product...E&gclsrc=aw.ds
#49
Get that gener-junk garbage out of here.
Get one of these:
Get one of these:
#50
Or dis:
#51
#52
i wouldn't even want filtered smoke in the house. (bat-safe) Ive had it happen. you wouldn't believe how long the smell lingers. could be years depending how much.
no thanks
#53
#54
and im not overcomplicating anthing, its about being less complicated and more portable, minimalistic.
and whats the big deal of multiple a/c d/c conversions? its only going back and forth once. does this
mean it stresses the system more for the same output?
#55
no if outside not no matter where you are. dont always need to charge in containment outside thats the beauty of charging outdoors. of course in a concentrated area with people at a facility like a track i would.. I agree about the contained charging but you are forgetting about the insane amount of smoke. no containment is smoke proof yet. I think thats common sense.
no thanks
no thanks
You are sounding like an individual who is fine with taking dangerous and unnecessary risks. I won't be responsible for any foreseeable disasters you will have and as such, I refuse to help any longer. Sell your equipment, and save yourself a predictable disaster. This is a hobby for responsible people, and you are clearly not a responsible person.
#56
So you're telling us you're okay with charging a lipo outside with no fire plan?
#57
broken link no joy
Figure you will lose approximately 10% for each "Step"
You would be going from the DC battery in the portable power station to AC (step 1) then from that AC power to your Mean Well power supply (step 2). The charger itself will have inefficiency taking in power from the power supply and converting to mAh going back into your batteries (step 3).
Going from the power station to the Mean Well supply to the charger means a 1,000wh battery is able to supply 1,000 * .9 = 900 * .9 = 810 * .9 = 729wh of useable capacity back into your batteries.
Going directly from a 1,000wh battery to the charger gives you 1,000 * .9 = 900wh of useable capacity back into your batteries.
