ICharger Duo 458
#76
Also keep in mind these "cheap" PSU's are so called refurbished ones.
#80
If the finished product has the (genuine) CE logo (which AFAIK is a requirement for distribution in the EU, but I may be wrong), it's legal. People should just be wary of cheap no-name Chinese clones without certification. However, I'm not involved in the ETS and I neither created that rule nor is it my job to enforce it.
#81
Quick question on my older duo the 410, I was able to create different profiles or models for my different packs. By just highlighting the battery in the main screen, then hitting the sys button and it would allow me to create a new profile for a battery or bring me into an edit mode.
So how in the world do I create different profiles for my lipos?
Thx guys.
Thx guys.
#82
Team EAM
EA
#87
Dumb question, but I was under the impression that "Regenerative discharge" feature was only for redirecting charge into another battery.
If this is the case, what is the difference between "Regenerative" and "Extra" discharge features?
Sorry, I'm new to the Ichargers platform. Picked up the 4512 Duo this week.
Thanks!
Thanks!
#88
Thanks!
Thanks!
#89
Thanks!
Thanks!
#90
Regenerative discharge uses the other channel and is used for discharging to a resistor bank, bulbs (some load) or another battery. Extra discharge is used on the same channel that your battery is on. You put a resistor bank in series with the battery. With extra discharge you need to determine the correct resistive load for the discharge rate you want.
My plan was to rig up eight to twelve 8ohm-100W resisters in parallel with some hefty heat sinks and fans. It's not going to be a travel kit by any means.
12pc. 8ohm-100W in parallel .7ohm resistance showing 1200 watts capable roughly.
8pc. 8ohm-100W in parallel 1ohm 800 watts capable roughly.
Is it bad to have too low of a combined ohm resistance for this scenario?
My goal was to have the ability to discharge a 6S 8000Mah Lipo at 30-40 amps if I wanted.
