ICharger Duo 458
#48
What power supplies are you guys using with this charger? Are there any that come with the EC8 connector?
#55
ur 1 ohm pic shows ch2 is power limited, the other 2 resistors are input current limited, I suggest u check ur settings are saved, since in pic 7 it shows that the charger is not auto saving, it will default to the default set program. Power limit can be changed in the menu option, I'm thinking u once set it to 240W discharge limit
#56
I've looked out the output power menu option. It only goes up to 80W per channel discharge and 1400W per channel charging. There is the option to favor a channel if your power supply can't handle the load. I'll switch that 2 channel 1 priority, but I don't think that should make a difference. The power supply is more than capable of the load, especially when most of the load is put on the battery.
#57
The settings are saved, I don't like autosave so I don't turn it on. Where are you seeing that it is power limited? And why would the banks with lower IR stop at lower power settings? I've sent an email to iCharger, but they will not be back until after their "New Year".
If all else fails maybe do a reset everything to default and try again
#58
Hmm look at page 37 of the manual and check with the relevant status indications on ur charger screen, i think it might give a clue, ICC icon tells me that somehow the input is stuck being held in constant current mode
#59
Yea its well within the operating limits, maybe theres a software bug, try resetting the thing to default or update firmware?
#60
I'll look for firmware update on the new charger and see if that changes anything.
