Server psu adding usb port >
Like Tree4Likes
  • 1 Post By the rc guy
  • 1 Post By belewis01
  • 1 Post By Alexv2024
  • 1 Post By Roelof
Old 12-20-2021 | 08:44 AM
Default Server psu adding usb port
So, I have a question regarding the DIY server PSU and making it a 12v power supply for charging needs. I have it fully working gor 12v with no problems, I just can't find the pinout for the dps 1200-fb to solder in a usb port. I know you can buy the one from RL power, but I'm cheap. Has anyone soldered in a usb port to their power supply? Does anyone have the RL power supply with usb attached to see the pinout for it? Pictures would be great.
Chasebanks is offline
Old 12-20-2021 | 09:59 AM
the rc guy's Avatar
.27 seconds to find
HP DPS-1200FB Power Supply Hack for charging LiPos (12 V / 24 V) (seidel-philipp.de)
hunterdawg likes this.
the rc guy is offline
Old 12-20-2021 | 10:18 AM
mrreet2001's Avatar
R/C Tech Elite Member
I am guessing he just uses something like
this this
(any automotive USB charger should work) I don't think most server power supplies have a 5v rail. At least not one exposed to the external pins.
mrreet2001 is offline
Old 12-20-2021 | 10:33 AM
the rc guy's Avatar
he clearly says 12v not 5.but whatever he has 130$ to blow.lol
Old 12-20-2021 | 11:31 AM
Roelof's Avatar
Yeah, such a simple USB PSU module is what you need.
Roelof is offline
Old 12-20-2021 | 11:41 AM
mrreet2001's Avatar
USB isn't 12v volts though. To solder a USB connector directly to the PS would only work if he can find a 5v rail / solder point or use a module like I linked.
FWIW he clearly said he had the 12v portion working already. So I am sure he doesn't need the guide you linked.
Old 12-20-2021 | 12:14 PM
Years ago I added USB to the HP power supply with an E Bay aftermarket 12V to USB convertor - something like this one - https://www.ebay.com/itm/23434376255...0AAOSwg7tfBr6B - I think the one I got was smaller, and it fit inside the PS. There are lots of cool options on Amazon as well.
Lately I prefer to us a power distribution board like this one - https://www.rcjuice.com/skyrc-power-...ion-board.html - I actually got a ProTek one, but I can't find it on AMain anymore.
mushroomed likes this.
belewis01 is offline
Old 12-20-2021 | 12:17 PM
Sorry rc guy, but he clearly asked about adding usb - multiple times ....
Old 12-20-2021 | 12:30 PM
Default Thanks
You are correct, I have the 12v rails working going to the charger itself. I was trying to get the pinout for finding the 5v rail/pin on the power supply. I do like the board version that converts everything if you have a spike in voltage..... probably just going to go that route. Thanks!
Old 12-20-2021 | 01:23 PM
Alexv2024's Avatar
Most of the "rc powersupplies" are USED server parts with 3d printed parts, stickers and a 12v to usb converter.
I took apart a damaged RL power supply (it was dropped) and this was the usb adapter on it. Expensive stuff for sure.
12v dc step down buck converter 12v dc step down buck converter
Alexv2024 is offline
Old 12-20-2021 | 11:44 PM
How about this:
Link to RCgroups
It doesn't seem that this power supply has a dedicated 5V rail, although there supposed to be some pins with 4,8V, according to the pinout pdf file attached.
Andi
andreas78 is offline
Old 12-21-2021 | 01:56 AM
Roelof's Avatar
And even if there is a 5v connection to use you need to do more than only connecting the power to a USB plug
USB charging without fear
gigaplex likes this.
Roelof is offline
Old 04-26-2022 | 06:34 PM
What was the result anyone find the usb 5v ?
Gordie88 is offline
Old 04-27-2022 | 05:29 AM
mrreet2001's Avatar
I am guessing he just uses something like this (any automotive USB charger should work) I don't think most server power supplies have a 5v rail. At least not one exposed to the external pins.
