Need help, servos sync issue >
Like Tree2Likes
  • 1 Post By Roelof
  • 1 Post By Bry195
Old 11-18-2021 | 11:11 PM
Post Need help, servos sync issue
Hi currently I'm using FlySky - FS-GT3B controller and receiver ( 3 channels, only using channel 1 and 2 as the 3rd channel is only for on/off function). With the set up for my RC boat, two motors to ESC and into channel 1 and two 360 degree servos into channel 2 ( via "Y" connector). While the motor throttle works in sync, the servo is not, with one servo always turning faster in either direction. Unfortunately, I can't attach or link the video demo now as the forum doesn't allow me If anyone knows how to fix these pls let me know!
P.S I know this can be solved if I get another controller/receiver with more channels and control them individually but currently I want to know if it can be fixed without getting another new controller.
Thomasthetrain is offline
Old 11-19-2021 | 01:44 AM
Roelof's Avatar
If both servo's are the same model then they should react the same if you have connected them to the same port. If they are far out of sync then you have one bad servo or they are just crappy designed.
gigaplex likes this.
Roelof is offline
Old 11-19-2021 | 03:18 AM
the rc guy's Avatar
test each servo individually on channel 1 that's the steering channel. then add your Y harness and check that each plug. like post 2 said if both still are way out then you have a bad servo id replace.
the rc guy is offline
Old 11-24-2021 | 09:02 PM
first-the servos must be the same. second the load on the servos must be the same (work). if all of this is the same then swap the servos mechanically and see if the speed moves with the servo. if it does then take the slow one apart and lube it minimally. if all of that is not helping then run the slow servo in by repetitive cycling the slow servo. if it gets slower (it shouldn’t) then run the other in with repetitive motion.
Bry195 is offline
Old 11-26-2021 | 12:43 AM
Thx for the replies. To clarify, we have 2 sets of identical servos during testing. So far we have swapped and interchanged most of the components and online research suggest every 360 servos will have some differences mechanically ( Coils, resistance, etc.) unless it is a 360 servo with an extra feedback pin (Which will not be compatible with our current 3-pin receiver). Right now I also found another device called a "matchbox" which is a servo adjuster, although the supplier suggests it will not 100% help but we will have to try. If the problem still persists, I'm afraid I have to get a better controller/receiver with more channels to allow individual control of each servo.
