Like Tree178Likes
Futaba 10PX
Old 03-22-2022 | 01:04 PM
  #151
DirkW's Avatar
Both Futaba and Sanwa produce really amazing radios, and you would not go wrong with either brand. Just buy and use what you want, for whatever reasons you have. It is not for others to decide whether those reasons are valid for you or not. Maybe if you get the chance hold them both in your hand (some prefer the feel of one over the other) and maybe look at the menus / controls (admittedly not Sanwa's strength), but it will be your radio, so you're the only one that has to be happy with that decision. The only bad thing about that is... you cannot "blame" anyone else once that decision is made, either.
Maven likes this.
DirkW is offline
Old 03-22-2022 | 02:09 PM
  #152
I own both radios now. Here are my thoughts on each.
M17
1. better balance and lighter weight
2. Easily adaptable to wireless charging. I don't currently have a need for wireless charging but can see it as a convenience for those who run 2-4 classes in a day.
3. Slightly smaller receivers. It's almost a wash though, both radios now have small receivers.
4. I can get multiple race days from a charge.
5. Price. No reason why the futaba should cost $230 more than the m17.
T10PX
1. Intuitive and easy to navigate menu system
2. Can program servos thru the radio, no external box required.
3. Receivers are 25%-30% smaller than older receivers
4. Radio seems to fit my larger hands better.
5. Very nice high resolution touch screen.
dawgmeat, choisan, eR1c and 1 others like this.
malkiy is offline
Old 03-22-2022 | 05:38 PM
  #153
oldfool's Avatar
Where does KOPropo rank?
oldfool is offline
Old 03-22-2022 | 06:52 PM
  #154
I haven’t owned a ko propo since the ex-1 kiy. The latency compare to the m12 was noticable.
I can’t really tell the difference in latency when comparing the m17 and t10px.
malkiy is offline
Old 03-23-2022 | 12:43 AM
  #155
DirkW's Avatar
I have not owned any KOPropo radio and haven't seen (m)any within the last couple of years, so I'd guess they are probably still solid (in the past they used to be very good, among the top), but maybe not quite up to the rest any more. But that's just my guess.
DirkW is offline
Old 03-23-2022 | 05:37 AM
  #156
oldfool's Avatar
I ran the first KO. It was quite the step up from my Futaba box radio.
oldfool is offline
Old 03-23-2022 | 07:47 PM
  #157
M17
T10PX
so I'm guessing , if the menu is easier to navigate and more intuitive for you and the latency is basically none exitant between the two . You think the futaba is better ?
Ggrant is offline
Old 03-23-2022 | 08:19 PM
  #158
disaster999's Avatar
Regional Moderator
Originally Posted by Maven
Theres no futaba wireless charging option for for the 10PX(there is for the 7 though....) You could install a $20 wireless pad in the housing like is common mod for the M17 but it would require a bit more wore as you'd need an adapter/splitter to attach the charge pad to the battery wiring as the Futaba pack doesn't have a charge port built in like the Sanwa does.
The 10PX uses a 2cell battery, no plug and play wireless charger out there will be able to charge that unless you custom make a circuitry or something. The M17 uses a single cell lipo pack AND has a micro usb port on the battery, thats why it is so easy to adapt wireless charging to it. You can just buy a wireless charging pad, plug it into the USB port and you're done.
gigaplex likes this.
disaster999 is offline
Old 03-24-2022 | 05:02 AM
  #159
Yeah, like I said, you'd need an adapter to work with the futaba plugs and a splitter so you can basically balance charge a 2S with inductive pads. The point of my post wasn't to lay forth a schematic and instructions to wirelessly charge the 10PX only to point out its not plug and play. I learned long ago sharing detailed wiring modifications via written medium only is a bad idea.
Maven is offline
Old 03-24-2022 | 06:24 AM
  #160
For me the T10PX is better. I like the software interface on the T10PX and it fits my hands better. My biggest complaint about futaba was the large receivers, they fixed that on the T10PX. I think futaba receivers stayed the same basic size for 20 years.
malkiy is offline
Old 03-24-2022 | 07:40 AM
  #161
I'm still really torn, but now leaning M17. There's just a value proposition there that for someone with no current brand investment and starting from scratch for 3-4 vehicles makes it hard to choose the 10PX or even 7PXR. I'll try to get some more wheel/interface the with the Sanww before I decide, but being able to get a radio, battery and 3 receivers for the price of just a 7PXR w/1 receiver and no battery makes it hard to justify the difference even with a virtually unlimited budget.
eR1c likes this.
Maven is offline
Old 03-24-2022 | 04:09 PM
  #162
i went from a 7pxr to the m17 for the speed then we got in a 10px i've found i'm having to slow my 10px speed down and i have feeling on my m17 on 7 just seems the futaba has finally caught up to sanwa in transit speed!
Ggrant likes this.
bagged17f350 is offline
Old 03-25-2022 | 03:10 PM
  #163
eR1c's Avatar
I've been w/ Futaba since 1985. -Seriously my first controller when I was like 15 was a Futaba. However I am really leaning towards the Sanwa M17 as an upgrade from my 4px.
Two huge reasons for me:
1) Price, the sanwa is $250 less than the 10px and about $100-$150 less than the 7px
2) Battery drain w/ Futaba is annoying and it is easy to convert M17 to wireless charging.
Price and battery are really what it comes down to for me. Otherwise both suit my needs just fine.
I can easily sell my futaba receivers to fund the price of new sanwa ones.
Had the 10px come w/ wireless and been $675ish in price I would jump on it.
STLNLST likes this.
eR1c is offline
Old 03-26-2022 | 02:46 AM
  #164
gigaplex's Avatar
The battery drain on the M17 is terrible. Wireless charging is just a band-aid in my opinion.
Ggrant likes this.
gigaplex is offline
Old 03-26-2022 | 04:49 AM
  #165
DirkW's Avatar
Without wireless charging, the M17 battery sure was a pain in the you-know-where. Now with wireless charging, IMO it has become bearable (still Sanwa needs to do some serious homework for future models).
DirkW is offline
