Like Tree1Likes
3PK question
Old 06-15-2021 | 10:01 AM
Default 3PK question
I recently obtained a used 3PK and I'm having issues trying to calibrate it with 2 different ECS's. (Mamba/Tekin) Issue is it can't find the "Neutral" that makes calibration complete. Throttle mode is set at 70/30, same as my other 3PK. Is this something that can be fixed or is something out of adjustment? Anyone else ever have this issue? These ESC's work just fine with another 3PK. Even tried different receivers, no change. Gotta be in the radio. Any ideas???
Andy Koback is offline
Old 06-15-2021 | 10:16 AM
Roelof's Avatar
You can set the throttle range to 50/50
http://manuals.hobbico.com/fut/3pk-manual.pdf
Roelof is offline
Old 06-15-2021 | 10:28 AM
Will try that tomorrow. racing tonight. I did set the Neutral width in the Tekin to factory setting of 56 up from 10 and made no difference.
Old 06-15-2021 | 12:34 PM
Try setting the throttle channel (ch 2) to reverse on your transmitter, then recalibrate.
AWB17 is offline
Old 06-15-2021 | 01:13 PM
Already tried that.
Old 06-15-2021 | 01:28 PM
bad advice for racing but good for crawling
Shawn B is offline
Old 06-15-2021 | 11:06 PM
Roelof's Avatar
Huh?????
The movement of the throttle/brake will still be 30/70 but the transmitter translate it to a 50/50 signal so the center is on the right spot with which several ESC's need to be. If the ESC does accept a 30/70 setting then by calibrating the ESC the ESC will make it a 50/50 translation.
So how can this be bad if it still happens anyway?
Andy Koback likes this.
Roelof is offline
Old 06-16-2021 | 06:06 AM
Huh?????
What competition esc needs to have the throttle set to 50/50?
Shawn B is offline
Old 06-16-2021 | 08:12 AM
Geezatec's Avatar
Try changing M-Sel(M1-10), where it set at could be corrupted. Make sure you bind RX w/o connecting the ESC. Then connect ESC and Config as normal. Ran into problem with Tekins RX8. Fine after that.
Geezatec is offline
Old 06-16-2021 | 08:33 AM
I did try another mode (M-11) and that seems to have helped. Trying a different ESC today to test.
Old 06-16-2021 | 08:34 AM
In my situation, I need to power the receiver by connecting the ESC for power.
Old 06-16-2021 | 03:32 PM
Geezatec's Avatar
All you need is this. plug it into Ch1-3 or Batt. It will bind. Thats how I bind all my RX. Futaba and Sanwa. I'm old schooled. Hope it help you! Good Luck!!
Geezatec is offline
Old 06-16-2021 | 03:50 PM
Forgot about those things. I was thinking receiver pack but that went out the window long time ago too. I went back to my regular 3PK and everything works as it should. The issue with this stand-by radio is it won't recognize the neutral band during calibration. Looks like a book end now. -)
Old 06-16-2021 | 08:36 PM
Geezatec's Avatar
Like AWB17 say Rev the direction of CH2. PK3 has that option.Menu go to CH-Rev, it'll show you CH1, CH2 & CH3, toggle CH2. Creation and Tekins have their Propietary set up on Neutral positions. Try it it wont hurt, cuz I've seen it when crossing over Creation and Tekins ESC's. Later!!!
Geezatec is offline
Old 06-17-2021 | 12:09 AM
Roelof's Avatar
Binding the receiver is only needed if the 3PK is equipped with a 2.4ghz TX/RX module system. I would not advise to use such a battery together with the ESC plugged, you can fry the BEC system.
If the steering servo does work then no binding is needed. If not tyou should also check if the transmitter is in the right mode PPM/HRS/PCM for the receiver.
Roelof is offline
