Like Tree1Likes
3PK question
Old 06-17-2021 | 08:30 AM
  #16
Originally Posted by Geezatec
Like AWB17 say Rev the direction of CH2. PK3 has that option.Menu go to CH-Rev, it'll show you CH1, CH2 & CH3, toggle CH2. Creation and Tekins have their Propietary set up on Neutral positions. Try it it wont hurt, cuz I've seen it when crossing over Creation and Tekins ESC's. Later!!!
Tried that. I know castle requires reverse for throttle. I think it's a potentiomiter issue that's out of adjustment or such. Parts are no longer available for the 3PK so I don't know if sending it in for a tune-up would be something they would do. The pot may need replacing and they won't do that because of parts discontinuation. save it for parts I guess. -(
Andy Koback is offline
Old 06-17-2021 | 08:33 AM
  #17
Originally Posted by Roelof
Binding the receiver is only needed if the 3PK is equipped with a 2.4ghz TX/RX module system. I would not advise to use such a battery together with the ESC plugged, you can fry the BEC system.
If the steering servo does work then no binding is needed. If not tyou should also check if the transmitter is in the right mode PPM/HRS/PCM for the receiver.
Radio had been working fine for a couple of months. This all started one day at the track. lost cal. after shutting radio off. Did a re-cal. and worked till radio was turned off again. After 3rd attempt, could not get it to cal. anymore. Think it wants to Retire".
