Like Tree2Likes
  • 1 Post By mes
  • 1 Post By Roelof
Futaba Servos
Old 12-21-2020 | 03:39 PM
Default Futaba Servos
Hi guys, I'm shifting from Sanwa to Futaba and would like to know your opinion as far as the selection of Futaba servos for the following categories:
1/8 nitro off-road (throttle & steering)
1/8 nitro on-road (throttle & steering)
1/10 4WD & 2WD off-road (steering)
Thank you!
peri is offline
Old 12-23-2020 | 11:51 PM
mes
Thank you!
If budget is not an issue, the CB700 is perfect for all the above applications, best servo I've ever had. If you're looking for a smaller and lighter option, the CT700 should be good. They are about to release a more budget friendly version with plastic tops and bottoms, iirc the 400 series.
mushroomed likes this.
mes is offline
Old 12-24-2020 | 08:31 AM
For 1/10 offroad the S9372sv is a beast but probably overkill even in a 4wd, but that's what I have in mine. The S9370sv is what I have in my 2wd buggy. You really only need about .12 speed and at the most 200 in/lb torque in 1/10.
Eric Tomczyk is offline
Old 12-24-2020 | 09:13 AM
Roelof's Avatar
If you are running Sanwa non SSR servo's you can use them on the Futaba. And regarding Futaba, only wanting to use the true SR mode you need Futaba SR servo's. You can use normal digitak servo's in SR mode if you set the channet to a normal servo.
Roelof is offline
Old 12-24-2020 | 10:28 AM
With no expense spared the best servo on the market would be the futaba ct700.
riceball777 is offline
Old 12-24-2020 | 11:48 AM
For 1/10 Touring Car, I like the Futaba BLS571HV or BLS551 servos.
glennhl is online now
Old 01-01-2021 | 09:24 AM
thank you guys! another question regarding servos: does the servo have to be of the same brand as the transmitter, technology-wise...do you gain anything in terms of communication, speed, etc if you use futaba servos with futaba transmitter or it doesnt matter at all?
peri is offline
Old 01-01-2021 | 09:32 AM
Only if your using Futaba SR servos with certain Futaba transmitters or Sanwa ssr with Sanwa transmitters. You gain speed. For us mere mortals it doesn’t mean much as the fast servos need slowed down for us anyways. You can mix/match brands and still have a very fast servo, just not lightning fast.
Jcharger13 is offline
Old 01-01-2021 | 09:48 AM
Suspended
There is a difference with resolution not to be confused with transit speed and the higher resolution gives a more connected feel to the race car as the system updates its processing at a faster rate. Transit speed is from point A to point B and different than resolution
brian mills is offline
Old 01-01-2021 | 10:18 AM
Roelof's Avatar
The faster the better. Yes, if you go from slow to fast it will be difficult to get used to, I experienced the same.
But when you are used to it you will never go back.
stanleyw808 likes this.
Roelof is offline
Old 01-05-2021 | 12:06 AM
thanks guys!
peri is offline
