Soldering station recommendation.
#17
Got tired of lugging my hakko 936 to the track so I got one of these coupled with a 15.00 24volt power supply from a local electronic shop and it kicks ass. Loads of power and comparable to my hakko in a small form factor. Can work with a 6s lipo too.
https://usa.banggood.com/Quicko-T12-...N&rmmds=search
#18
The above route by Minh is a pretty good option, it uses knockoff Hakko T12/T15 direct-drive tip cartridges which deliver more heat than any of the 936 clones, or the ToAuto iron above. The use of an external power supply (usually a laptop one) eliminates the need for a sketchy Chinese internal one. The biggest downside is probably the tip-to-finger distance which will be double a hakko fm-2027. But for casual soldering, that's a killer deal.
For anyone curious, that setup will deliver more power than any of the TS100 rebrands and clones (1up and maclan) and be on par with the maxline unit.
#19
Input voltage Electricity Accessibility power
19V ≥2.38A 45W
20V ≥2.50A 50W
21V ≥2.63A 55W
22V ≥2.75A 61W
23V ≥2.88A 66W
24V ≥3.00A 72W
#20
Used crappy irons for a few years. When I got into wrenching on real cars and doing electrical work 25 years ago, I got a Weller WLC-100 and thought it was a great upgrade from the $15 specials. It worked, but took forever to heat up and was easily exhausted. Fast forward 20 years and I finally got sick of it, and bought a Hakko FX-888D... I'm pissed I spent 20 years with the Weller and didn't go Hakko earlier. Heats up in seconds and solders anything I can throw at it (I've only tried up to 10ga though).
I also got the Arrowmax soldering iron kit for mobile pit use, and it is great. I did the 6S battery thing to run it at 24v for a while, but after forgetting it too many times, I tried it on 12v directly off my power supply, and it still solders surprisingly well - I have no problem soldering the most expensive motors with 12ga wiring with it. In and out in seconds, just like my FX-888D. I don't even bother with >12v anymore.
The two biggest lessons I've learned in 25 years of soldering:
1. When soldering heavy gauge wires, use the biggest tip you can fit in the workspace - it acts as a thermal reserve and keeps the tip hotter, longer during the soldering process.
2. Use a clean tip. In the pit, I use at least a wet sponge. At home, both wet sponge and brass wool at the ready.
#21
That Weller WLC-100 model is not even a true Weller, that model is sold with many brand names.
After using a Weller WECP20 for about 30 years and having some issues lately I bought my self a new Weller WE1010 about an half year ago. This is like a late follow up model of the WECP20 but now with a 70W iron instead of a 50W. The tips are very cheap, easy to get and I did read do also fit the older WECP20, I directly bought some tips with it from small to the biggest and works awesome. I love the standby function when not using it for a certain time, it does save tips..
#22
Uve had 1 of these in my stable since the 80's never had a failure . mobile smaller and has great heat ups.
master appliance ut 100
UT-100SIK Master Appliance Co | Soldering, Desoldering, Rework Products | DigiKey
#23
#24
I've used Weller for years, but I finally broke down and bought this:
https://www.amainhobbies.com/thermal...amain/p1201928
Works great; and works well with my non-rc applications as well.
#25
#26
One of my preferred soldering stations for simple soldering tasks is the Weller WLC100. This soldering equipment is a lightweight, high-quality item for everyday applications. For ease of use, it actually includes a soldering station, copper ti, iron holder, and cleaning pad.
#27
#28
I paid about $55-65 over a year ago for this, seems to be be what a lot of the RC soldering irons are based off of. I bought it from a local electronics store that sells good stuff. Works great and Im sure it'll last a long time. Soldered wires on ESCs, and all general rc stuff.
Even repaired my headphones and their tiny wires.
6Likes
