Trouble calibrating ESC >
Old 10-11-2020 | 06:31 AM
  #16
the rc guy's Avatar
this is getting good. rx has a bec(not)..theres a sequence to pulling and pushing the trigger the esc beeps to tell you it has recognized the trigger pull or push or neutral position.
the rc guy is offline
Old 10-11-2020 | 09:18 AM
  #17
jko
yes, it's no related to because at all. sounds like he's not getting the first beep for recognizing neutral. when i used an old am radio i had to change the throttle trim before i would get the first beep. At first i just moved the throttle trigger slightly in either direction to see if i can get the first beep
jko is offline
Old 10-11-2020 | 10:39 AM
  #18
Geezatec's Avatar
If not getting 1st beep in neutral, read TX manual to reverse TX. Second way make sure the A,B,C motor connection are correct. and switch A and C leads to ESC.. Once you get the 1st Beep in will calibrate.
Geezatec is offline
