Picking a new ESC
#16
Hobbywing is probably the pinnacle of ESC's right now, Theres always someone who has issues with tekin locally, those same people also say tekins customer support is good - sure it is but why is it needed? i would much rather have a reliable product than have to worry about "downtime" waiting for a new esc, tekin are who they are because of sponsoring drivers, the same as novak was but wheres novak now?
#17
Now....to be fair, that was ages ago, maybe their products are more reliable now. I treat all my ESCs the same. I've never had to deal with customer service from Hobbywing, Castle, or Speed Passion. I did email Orca once to fix a ESC that I did reverse polarity on, but that was entirely my fault. I'm all for supporting an american product, but I expect quality.
#18
In all seriousness. What is it that makes these better? What class do are you using them in? How has the use of this ESC changed you from a midpack to a front pack racer? I am looking for that magic bullet. If this ESC is it. Sign me up, but I want to know what am I missing? I have never heard of this brand or seen them. Where do you even buy them?
#19
https://pro-performancerc.com/?product=xsc150p-esc
Each esc will be setup slightly different than others, and that can improve a driver's speed if it's set the way they race. If i had to guess what makes it different/ better. It would be that pro has focused on lowering the heat/ ir of the esc, so it packs more of a continued punch. Spec wise, it doesn't seem much different than a xr10.
#20
Guys keep this discussion clean and cordial. If you're going to resort to personal attacks you may well find moderator staff are more than happy to sit you in the time out box for a while.
Remember, toy cars.......
#22
...oh and I use the R1 V3 ESC
I tried Tekin, what a red hot piece of s... that was, felt like the car had a 2kg weight on the back of it in their blinky mode.
Hobbywing, yeah lots of people like them very popular I just liked the R1's data logging interface on android better although it needs the wifi module installed to log, did use the Maclan for the logging and onboard USB host but the interface was limited and connection via usb was a bit temperamental.
#23
#24
Each esc will be setup slightly different than others, and that can improve a driver's speed if it's set the way they race. If i had to guess oc what makes it different/ better. It would be that pro has focused on lowering the heat/ ir of the esc, so it packs more of a continued punch. Spec wise, it doesn't seem much different than a xr10.
#25
you only have a few variables that an RC esc manages. Because most escs have so little going on hardware failures should be very minimal. but are they? Most electronics fail from over temp, exceeding shock specifications for the electronics and in some cases bad assembly. Coming from a MFG and starting out as the guy taking calls from customers that couldnt make it do what it does I can say that if you are buying from a reputable mfg that when a tech at the MFG gets a call he has everyone go through the basics. Because when you sell 1000’s of a product you get a feel for how good the devices are and 90% of the time its user error. its more expensive to repair a product than to just replace it after you add the cost of educating the user on what they did wrong.
Logging is great if you can do something with it but im glad its available. I think that what people see as a difference from a driving perspective is obviously if the product is trouble free. I think the thing that distinguishes hobbywing on some of their products is being able to shape the acceleration and deceleration rates of powerful motors in stages.
#26
I know Dalts who was also a supported driver over here went through 5 V3 esc's in a 6 month period before giving up on them and going to Hobbywing which he hasn't had an issue with
So I learnt my lesson, and stopped using their ESC's and then their motors (Saw a few V3 Actiniums with stator shorts) etc. Can't promote a product you can't have faith in to last a race.
#27
A few here run the Radon ESC, and when I was a Team Powers 'supported driver' I tried a V3 and found for outdoor asphalt it was poorly sealed, so dust and dirt etc very easily got into the case, under the pcb etc and that created issues which they then refused to warranty.
I have had a defective V3 Actinium motor, the stator laminations had gaps. But the replacement was good and performs well. They do seem to have some QA issues.
#29
#30
It's good to see HobbyWing getting so much love in this thread. I've been an advocate of them for years and people used to laugh at me. They deserve the credit they are getting. Their stuff just works and it's very reliable. They even made a huge splash in the crawling world.
Tekin is also great. Personally I've never had any of their ESC's or motors fail. And the customer service is second to none. Also it's an American company which should get much more weight than it does.
WHO? Too many other good, reliable brands to take a gamble on something with a name like "Pro Performance" IMO.
Castle is not for racing and Tekin is preferred by those who don’t know any better. The HOBBYWING XR10Pro G2 is the “standard” top of the line HW for 1/10 competition. If you want something that is faster on the clock check out the XSC150P from a company called PRO PERFORMANCE RC. I have run nearly every esc available on the market these days and the XSC150P is my preference. The difference in power output and drivability over the HW is extremely noticeable and the tuning support and after sales service is second to none.
79Likes
