Calibration
I got a new receiver because the last one shorted the new receiver is a fs-Gr3e reason i got this is because the transmitter is backward compatible (its a redcat RCR-2CE) i was able to bind it but when i try to calibrate it to my Max 8 it wont do anything i can set the neutral but froward and reverse don't want to set, only way i can set it by maxing out the trim for the throttle and once i do that and zero the trim it wont move the tires or move them slowly can anyone please help i been trying to figure this out for 3 hours now and nothing i seen so far online has helped
I went and tried it and the servo bearly moves and both channels I noticed like the receiver has no power. And I can't even calibrate it on the steering channel like I did when my last receiver went out
Okay I'll see if it's putting out voltage but what I don't get is when I had my original receiver that came with the remote it was fine it had no problem calibrating but I did have to use channel one witch is steering bc my 2nd channel was shot but it was fine and had no problems could it be that it's the receiver?
