Setting servos on basic tx dx2e help
So I知 looking for tips or tricks on how to set up my serval for the throttle so it doesn稚 overextend and cause flex I can do it with my fly sky but with the basic spectrum I知 having trouble
Taken from the DX2E manual available on the spektrumrc website.
The travel function supports precise endpoint adjustments in each direction for the steering and throttle channels.
1. Hold the trigger in the full brake position and the steering wheel in full right position while powering on the transmitter. The LED flashes rapidly, indicating the programming mode is active.
2. Throttle End Point: Hold the trigger in the full throttle position. Turn the TH TRIM knob to adjust the full throttle end point.
3. Brake End Point: Hold the trigger in the full brake position. Turn the TH TRIM knob to adjust the full brake end point. Return the trigger to the center position.
4. Left Steering End Point: Hold the steering wheel in the full left position. Turn the ST TRIM knob to adjust the left end point.
5. Right Steering End Point: Hold the steering wheel in the full right position. Turn the ST TRIM knob to adjust the right end point. Return the steering wheel to the center position.
6. Power off the transmitter to save the travel adjust settings. The minimum Travel is 75%, and the Maximum travel is 150%. The default travel settings are 125% steering and 100% throttle.
IMPORTANT: If the travel is changed on the DX2E, you must rebind and calibrate AVCョ Receivers.
Funny, it is not mentioned in the manual:
https://www.spektrumrc.com/ProdInfo/...%20_Manual.pdf
But there seems a topic on this forums:
Spectrum DX2E Endpoints?
To be honest, it seems no normal setting but a recalibration option, if you can set it mechanical then that would be my 1st choice.
You can use the steps listed above to change the travel. Also with the 2e you can use the SPM6741 Bluetooth module with the Spektrum Dashboard app and make end point adjustments with the Dashboard App.
1Likes
