Like Tree700Likes
FlySky Noble NB4
Old 06-12-2023 | 03:56 PM
  #1396
RazorRC's Avatar
Comparison with the RC8X: https://youtu.be/8tPezVia_jg
RazorRC is offline
Old 06-12-2023 | 04:36 PM
  #1397
Raman's Avatar
Marc Rheinard will officially represents Flysky
https://www.redrc.net/2023/06/rheina...l-with-flysky/
Raman is offline
Old 06-12-2023 | 11:26 PM
  #1398
gigaplex's Avatar
Originally Posted by Raman
Marc Rheinard will officially represents SkyRC
SkyRC and Flysky are two different brands.
STLNLST, Raman and Panther6834 like this.
gigaplex is online now
Old 06-13-2023 | 11:58 AM
  #1399
Originally Posted by Werty Yui
It has Infact been confirmed that this situation applies to both the NB4 and the NB4 Pro. There is a fix and that is to bind aftermarket RX in "1 way" mode. This may or may not fix the problem for those that prefer the telemetry capability and have now lost it when binding in that mode. Also, not sure if this fix applies to EVO receivers.
I don't think the EVO receivers would need such a 'fix'. I believe they are either made by FlySky, or are made under permission by FlySky, thus they should still work properly.
Panther6834 is offline
Old 06-13-2023 | 12:35 PM
  #1400
Team EAM
Reading comprehension is very hard in the US!
EA
STLNLST, Lonestar and Raman like this.
EAMotorsports is offline
Old 06-13-2023 | 04:14 PM
  #1401
Raman's Avatar
My brain is in veg state lately. I meant he is sponsored by Flysky lol.
Raman is offline
Old 06-14-2023 | 07:38 AM
  #1402
Team EAM
We all knew that but we like being smart a--es most days!
Lonestar and gigaplex like this.
Old 06-14-2023 | 11:39 AM
  #1403
Raman's Avatar
I usually right there with you, when I’m functioning. Tomorrow I go on 10 vacation, hope to recuperate some brain function
Lonestar likes this.
Raman is offline
Old 06-20-2023 | 08:25 PM
  #1404
Hey Guys, I just received my NB4 and FS-RM005 mini-z module, and question if I should update the firmware on the radio or not. It has 2. 0. 99std. installed from the factory, and that's what Flysky says the RM005 needs. I figured the updated firmware is good with the RM005, but after reading some having problems after updating, I just want to be sure! This is my first updatable Radio, so I don't want to screw anything up. I will only be running Ready Sets until I get my PN2.5 built, then I will probably use an EVO board since I now have 2 receivers.
I'm watching WTF RC Cars u-tube videos and learning alot, but I haven't seen one that covered this.
Thanks, Take Care and Drive Fast! Drew
Update: Got everything installed and bound to my 2 Ready Set MR-03's, and it worked great. After watching all WTF RC Cars, u tube videos, I felt confident in updating the NB4 to FW 2.0.102 STD version, and following his instructions it updated and is working GREAT!!! I ran a few dozen laps with my 98mm Stock Class MR-03, and turned my fastest lap on this months Mini96WC layout of 3.99 seconds, and my overall lap times went down 3 tenths! I did nothing to the car other than change the radio! Can't wait to see what I can do after getting it/me dialed in! Also the car goes into reverse almost flawlessly now, where with the factory radio took forever to reverse!
BoxxerBoyDrew is offline
Old 06-27-2023 | 04:52 AM
  #1405
Default Updating problems
Hello nb4 group I love my nb4 had it for 3 years never thought to update it tried to update now, I have a blank screen, it re starts says welcome to noble then says needs firmware update when I try to update it only makes it to 7% tried the rest button does the same and to make it worst I tried my back up tx and it's doing the same anyone had this problem or can help me get back to the track thank you
shawn stephens is offline
Old 06-27-2023 | 06:09 AM
  #1406
Is the NB4 charged? While I haven't run into the problem you're having with the NB4, I have run into that same type of problem with other devices. In almost all situations, it was caused by the device not being charged enough.
Old 06-28-2023 | 07:59 AM
  #1407
3 years? I would try updating to an older version but newer than you have, then to the latest.
Timw is offline
Old 06-28-2023 | 08:13 AM
  #1408
Agreed. If there's have been a few updates between what's install, and the most recent, it's definitely best to install to reach of the updates released, is for no other reason than to be on the "safe side". Besides, sometimes, updates can be released for devices that require a certain previous update to be installed first.
Old 06-29-2023 | 08:38 AM
  #1409
although, I can't say I've ever seen failure to start with the update message. Assuming its bricked, maybe the internal Li-ion doesn't have enough charge to boot? But, in theory you'd have the external battery connected so....
Timw is offline
Old 06-29-2023 | 08:53 AM
  #1410
That only helps IF the external pack is turned on.
