Like Tree700Likes
FlySky Noble NB4
Old 11-12-2021 | 11:53 AM
  #1111
Speaking of the Mini Z, I guess I should have waited because I paid nearly $50 to get the module shipped to me. its msrp is $29.99 at Kyosho and in stock (US)
https://www.kyoshoamerica.com/82151-...ini-zfhss.html
doh!
Timw is offline
Old 11-21-2021 | 08:18 AM
  #1112
Has anyone figured out how to re-order the model list?
Cromulent is offline
Old 11-21-2021 | 09:43 PM
  #1113
As far as I know, you can't do that on the radio itself. You can however, use the Flysky PC backup tool and do it through there even though it wasn't designed to be used in that way.
What you can do via the tool is first backup all your models. After, you can delete the models on your transmitter via the tool by loading the models, in some cases, one by one, to the new desired slot. This will make sense once you start doing it. Yes it's cumbersome but the tool wasn't even designed for that in the first place and there is no other way on this radio. Model list configuration is not something that's common for most RC surface radios.
ebaltazar and Cromulent like this.
Werty Yui is offline
Old 11-30-2021 | 07:39 PM
  #1114
any speed runner here tried pairing FTr10 reciever to nb4?
bratan is offline
Old 12-30-2021 | 04:55 PM
  #1115
Default Replacement screen
Sorry to barge in. I just joined to ask how you were able to get a replacement screen from FS. Ive been trying for a while and my screen is also shot. The wire split in two.
any reply would be greatly apprciated.
Brian
Brian6796 is offline
Old 12-31-2021 | 06:22 PM
  #1116
https://www.teampowersusa.com/Flysky...een_p_424.html
Looks like my LHS is selling parts now (see link above). Should make the radio even more compelling. I'm curious if they will sell replacement batteries so I can hot-swap them during a race if I forget to charge or something.
TOM MAR, ebaltazar and gwc like this.
rcbuggy88 is offline
Old 01-02-2022 | 09:19 AM
  #1117
Chris Prelot's Avatar
did anyone fund a solution to connect the Noble nb4 on a PC into the Flysky Assistant? I want to update to 2.0.93
I tried everything many different ,usb cable , different PC , reboot with the transmiter on still I can't have the transmitter recognized...
i follow WTF RC Cars video but still can't make it work
thanks
Chris Prelot is offline
Old 01-02-2022 | 09:44 AM
  #1118
thanks
Good luck Chris. I tried many options and am stuck like you are. Last option Flysky recommended was find another NB4 user and swap the external batt and try connecting to PC. 🤷🏻
s550v is offline
Old 01-02-2022 | 11:48 AM
  #1119
thanks
had a same problem, charging cables won't work, you need a sync micro usb
bratan is offline
Old 01-11-2022 | 10:36 AM
  #1120
Very interested in the NB4 radio and this thread has been a great resource. Just getting back into the RC world after a long hiatus - have a couple boys now that are enjoying their new mini-b's and a TRX4.
Is there any reason not to get the NB4 over the PRO? I'm going to build a 1/10 buggy soon and will need a transmitter. The NB4 ticks all the boxes for tx cost, rx cost, channels, stored vehicles, ease of use, etc. I'd be using this for my mini-t 2.0 brushless and any new vehicles I acquire which would likely include crawlers. Would prefer to not spend $400 when all I need I can get for $200-250 with the NB4. TIA
trom2k is offline
Old 01-18-2022 | 09:38 AM
  #1121
TheBeave's Avatar
Has anyone tried upgrading the firmware on a regular NB4 to the NB4 Pro firmware? Curious to see if their enhancements in response rate are actually mechanical or software related. I would think since they can use the same receiver it's software related, I could be wrong through.
TheBeave is offline
Old 01-18-2022 | 12:36 PM
  #1122
thanks
I had to dig an old USB 2.0 hub out of the computer graveyard to have mine communicate properly. Have you tried that?
gwc likes this.
Old 01-20-2022 | 08:10 PM
  #1123
Just noticed that my LHS is selling replacement batteries. Nice to know that I can get a replacement when mine eventually dies. $50 is not that bad, especially since the battery is in an aluminium shell. I thought about getting one to have a spare and hot-swap while at the track if my battery gets low, but the battery lasts long enough anyway, and it's not like I can't just plug it in...
https://www.teampowersusa.com/Flysky...ery_p_428.html
Old 02-02-2022 | 08:38 AM
  #1124
Default Unique model setting?
Is there a way to set the radio up so model 1 does not control model 2 and so on? Im finding this quite annoying... I can set my sanwa so each model has a specific ID so you do not accidentally get on track and monkey with your sub trims on model to accidentally when you're supposed to be driving car model 3
EHubz is offline
Old 02-02-2022 | 09:26 AM
  #1125
For any NB4 items, if NorCal doesn't have it in stock, you can always ask Erik to order it. He's always been great at getting almost everything I've needed in the past.
Panther6834 is offline
