FlySky Noble NB4
#1126
Received an NB4 over the weekend and started messing around with it. I don't have a lot to compare to as the last real radio I had was a Futaba 2ch crystal. This must be what my grandparents experienced seeing smartphones for the first time lol.
The transmitter was on FW ver 2.0.85 (I think...) and I updated to 2.093 FCC and then 2.0.100 FCC versions hoping I would bind a receiver after the .93 upgrade and not have to rebind but that was not the case. Had to put the receiver into force bind to get them to update after updating the Tx. Aside from the not so straightforward firmware updating this seems like a really great setup and easy to navigate/use.
I did have some confusion with the Assistant. The download is a .rar file and you need to use 7zip (or something else that can extract the contents) to get to the .exe to run it. That was a bit of a frustration as well but got it all up and running. Just ordered another FGr4S v2 for my B74.1D build. Looking forward to getting more stick (wheel?) time with this remote. Great feel in the hand.
#1127
I've started the build of my B74.1D and am looking for servo suggestions for something that would work well for the buggy and the NB4transmitter. I know that I could drop just about any servo in and it would work but is there a protocol that I should look for that functions like Futaba's SR or Sanwa's SXR but for the NB4? I'm currently looking at the below servos for the build. I'll be using a FGr4S v2 for the receiver.
Savox SC1258TG
AGF A65BHL
ProTek 160T or 160TBL (both more than I want to spend)
Savox SC1258TG
AGF A65BHL
#1129
Savox SC1258TG
AGF A65BHL
Savox SC1258TG
AGF A65BHL
#1130
Savox SC1258TG
AGF A65BHL
Savox SC1258TG
AGF A65BHL
#1131
I just updated to firmware 2.0.100FCC, rebound my FRg4s, plus others, and everything works fine with no need to update any of the RX firmware before re-binding.
If someone out there does experience an issue with binding a receiver, it could mean the receiver has an old FW on it and may require a forced update to the current version. Moving forward, you should have this issue no longer.
#1132
Seems like you & I are, essentially, in the same boat. I'm also building a B74.1, albeit, the Astro/Carpet Team Edition (ie. not the 'D'). First, I find it "interesting" that you indicate both ProTek servos are "more than you want to spend", yet the AGF isn't much cheaper...plus, none of them (including the Savox) are waterproof. Regarding Savox, personally, I avoid them. They are overly-noisy, and "power hogs". As I'll be racing on a carpet track, 'needing' a waterproof servo isn't a concern...but, when racing on dirt/clay, you should strongly consider a waterproof servo. This might sound like a strange/unusual choice, but I'll be installing the ProTek 140T - it's just as fast, and almost as strong, as the others, at a lower cost (ok, so, technically, it's about the same price as the AGF)...plus, it's waterproof. And, if you purchase from Amain, and it has any problems (not that I've ever had ANY problems with ProTek servos), warranty replacement is super-simple.
after a lot of digging and looking around I ended up going with a Blue Bird BLM-M91S. It’s a low profile servo and seems pretty bomb proof from what I’ve read. About $20 less than a ProTek 160TBL but uses a magnetic sensor instead of a pot. I don’t have it in hand yet but Redwing RC just put in an order so hopefully soon.
I’ll have to report back once I get it setup.
#1133
One thing to note: Starting from firmware 2.0.93 through current, one no longer needs to update the receiver's firmware after updating the radios F.W. You still need to re-bind though.
Awesome, that’s good to know. Thanks for the info. Should make the process a little faster moving forward.
gotta say, really liking the Tx. Haven’t dug into many settings yet but as far as feel and usability it’s great. Just have it run I g a brushless mini-T right now so first setting I’m going to mess with is the throttle mapping so I don’t wheelie as much.
#1134
Just got my Noble in the mail tonight...
I did get the two antenna-less receivers (Fgr4s) and the one huge telemetry type (if it don't fit in my crawler receiver box will be trashed)....
What i'm looking for is the smallest mini/micro receiver that will fit in my SCX24's and other mini RC's. The 4s WILL fit (as I used to run the Sanwa 481/482's but would rather have something smaller if able.
#1135
https://www.flysky-cn.com/gmr-specifications
#1137
Flysky has a list of receivers on their webpage, one of which is the smallest they offer....
#1138
#1139
WHY would you have even tried to shove an FGR4S inside an SCX24??? There ARE micro receivers for the Noble NB4 (DasMikro even makes a micro ESC/Rx for the Noble NB4). DON'T "complain" about something that you did...you chose to use an Rx in something too small for it. That's like shoving a Chevy 454 inside a Volkswagen Beetle, and then complaining that the engine is too big for the car (for those wondering, you can fit a Porsche Flat-6 inside an old Bug).
#1140
It fits fine, anyways, just had to let it hang off the side a little.
But when I can get tiny receivers like this R4FGM for half the cost, it's hard to not want to switch over.
BTW, the FGR4 mentioned above a few posts ago that comes with the NB4 is pretty much useless. I had to decase it and shove it into the receiver box on my Tekno MT410. Don't tell me that's like shoving some V8 into some tiny car. That receiver box fits almost any other receiver but the FGR4 is so big it doesn't fit into anything. It wouldn't fit into my TRX4 receiver box either. There is no reason it needs to be that massive.
I probably should have known the NB4 fanboys would come out swinging if I had any complaints at all.
700Likes
