New Spektrum DX5 Pro >
Like Tree19Likes
Old 06-25-2019 | 02:26 AM
  #151
No, "I" switch is not being used
Taper is offline
Old 06-25-2019 | 11:04 AM
  #152
nikos2002's Avatar
Originally Posted by Taper
Nobody?
Taper - check your PM for some questions. Thanks. Nick
nikos2002 is offline
Old 07-04-2019 | 11:57 PM
  #153
Do you received my PM?
Taper is offline
Old 07-05-2019 | 06:52 AM
  #154
strodedawg's Avatar
looking to grab a receiver for my electric 5B. What receivers does anyone recommend, running spektrum servos also. thanks
strodedawg is offline
Old 07-05-2019 | 08:55 AM
  #155
How many channels do you need?
I would look at the new line which doesn't use bind plugs any longer (215, 315, or 515 based on your channel needs).
Mahjik is offline
Old 07-05-2019 | 09:30 AM
  #156
strodedawg's Avatar
I need three throttle steering and transponder and maybe another for a fan maybe
Old 07-05-2019 | 09:34 AM
  #157
strodedawg's Avatar
Would an sr2100 like I have in my other cars work, as I could just borrow one of them
Old 07-05-2019 | 03:31 PM
  #158
Do you need 5.5ms for the vehicle? It should work, but personally after using their receivers that don't require bind plugs, I have a hard time recommending their older models.
Mahjik is offline
Old 07-05-2019 | 04:03 PM
  #159
strodedawg's Avatar
the newer sr2100 without the bind plug I have an extra. I wonder if the range would be fine for the large 5th scale tracks
Old 07-10-2019 | 01:33 AM
  #160
Taper is offline
Old 07-12-2019 | 11:16 AM
  #161
nikos2002's Avatar
Taper --- yes.. answered.
strodedawg - for the 5B would recommend something with an antenna to get it up off that chassis of the 5th scale. SR315/515 depending on ports you need.
Old 08-05-2019 | 03:00 AM
  #162
Thanks for you help Nick!
Taper is offline
Old 08-06-2019 | 10:08 AM
  #163
Hey Nick, I just had a quick question, any idea when a new raceware is going to be coming out. 1.04 is almost a year and a half old at this point? Just thought I would ask, thank you very much, E
edjo69 is offline
Old 08-20-2019 | 03:26 PM
  #164
nikos2002's Avatar
Hey E, sorry haven't been on rc tech for a while... busy making new Spektrum stuff!!!! Always something in the pipeline!!!
Old 08-22-2019 | 02:09 PM
  #165
With no charging jack included, how long will the lithium battery plug hold out If one chooses to run a an alternative battery while having to remove it to charge it over and over again?
evlwevl is offline
