Like Tree8Likes
Tekin Servos
Old 12-05-2017 | 09:42 PM
R/C Tech Elite Member
Default Tekin Servos
Tekin officially introduced their new line of servos.
T120 all the way up to the T400, supporting everything from 1:10, 1:8 and Crawlers.
Tekin - Servos
mlax is offline
Old 12-05-2017 | 10:13 PM
Nice servos...
Hands001 is offline
Old 12-06-2017 | 04:25 AM
Which torque spec should we be looking at when comparing specs to other brands of servos?
anr211 is offline
Old 12-06-2017 | 05:12 AM
Very good question!
For example the t-120 and t-180 have close to the same speed but one has 50% more torque, at that point why should I buy the t-120? Or the t-250 vs the t-300 which are very close in specs? Are they brushless? I get the gears are CNC metal but are they steel, titanium...? Hope Tekin guys don't take this wrong.
30Tooth is offline
Old 12-06-2017 | 05:31 AM
Originally Posted by 30Tooth
Very good question!
That is a fine question, but I was wanting to know if other servo brands are rated in what Tekin is calling torque or dynamic torque. I've never seen two different torque specs listed on the same servo before.
anr211 is offline
Old 12-06-2017 | 06:04 AM
What's their policy on stripped gears, are they covered under warranty?
It's not clear based on what I'm reading here:
Originally Posted by Tekin Product Page
OUR QUALITY PROMISE
We guarantee our servos to be free from manufacturer defects for 365 days from date of purchase. All items are tested in a controlled environment prior to the packaging process to ensure you receive a top quality Tekin product. We strive to provide the highest grade professional components possible and we appreciate and treat every Tekin user as part of our family. We are RC enthusiasts designing and manufacturing quality products to give our fellow RC enthusiasts the best hobby experience possible.
billdelong is offline
Old 12-06-2017 | 06:05 AM
1/8 IC Fan's Avatar
The torque i believe is from a still servo, beginning initial arm movement, and dynamic is while moving through its range of motion.
This is yet to be confirmed by Tekin.
1/8 IC Fan is offline
Old 12-06-2017 | 06:08 AM
JRSlash's Avatar
I like the LP servo. Any pricing yet?
JRSlash is offline
Old 12-06-2017 | 06:34 AM
The plain/running torque is the maximum weight the servo can move (e.g. the servo lifting a 10kg weight), dynamic torque is stall torque as the amount of force the servo can sustain until it can no longer hold it.
IMO, if it does not explicitly state that it is covered by the warranty then it isn't covered.
1/8 IC Fan likes this.
30Tooth is offline
Old 12-06-2017 | 07:50 AM
Yeah, I tend to agree with this line of thought.... I have to wonder if they will offer any gear replacement sets, not seeing any posted yet.
Old 12-06-2017 | 08:26 AM
EbbTide's Avatar
If they don't offer gear sets then these things better be VERY well priced lol
EbbTide is offline
Old 12-06-2017 | 08:48 AM
Darkgenerals's Avatar
Very good question!
lol nice side step of the question
so essentially the same thing?
in the case of the T360, it can only lift 382 Oz but but also lift 479? Something doesn't make sense about that. If your servo stalls at 480, why not say its max torque is 470 and forget goofy things like dynamic torque.
Comparing just the T-360 vs a savox 1230SG, the savox will be a better buy unless Tekin can keep the price down but Tekin is very proud of their stuff, so I bet these will be prohibitively expensive.
Darkgenerals is offline
Old 12-06-2017 | 03:43 PM
I should've tried harder to explain myself the thing is:
-the t-360 can lift 382oz from the ground and do reps like an exercise but if you power the servo and then attach a load it can hold 479oz because it isn't doing "exercise", just holding it. Once it has to move, the limit is 382oz. Further answering your question, if a manufacturer rated servos for stall then that t-360 would have serious problems steering or braking anything requiring above 382oz of force.
30Tooth is offline
Old 12-06-2017 | 06:11 PM
I get what your saying but using something like dynamic torque as a marketing point is misleading. I dont think any other large servo makers use that. I still think savox will offer the better deal, but Tekin does make good products. Just call it 382oz of torque and let everything else be gravy.
Old 12-07-2017 | 02:20 AM
Agreed! Most servo manufacturers rate at running torque, particularly those brands you see on the airfield, I use brands trusted at the airfield as rc airplanes are very expensive and any servo that gets their seal of approval is surely good. Also, those brands tend to rate the servos conservatively.
Tekin Servos
So, coreless servos.
30Tooth is offline
